Quantcast Differentials - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Differentials
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 02-20-2006, 09:57 PM   #1
Chest_Rockwell
Differentials
I just wanted to check and make sure that I'm doing this right. I'm filling up my front and rear diffs (Dana 30 & 35) with my new Rockcrusher covers on. I'm use to filling up to the bottom of the fill hole, however I'm told that i can't do this with the Rockcrushers because of the excess gear oil blowing out the vent line. I looked at my manual and it says 1.18 liters for the front and 1.66 liters for the rear. This works out to be 1.24 quarts for the front and 1.75 quarts for the rear. Does this sound right? I ended up filling the front 2 quarts and the rear 2.5 quarts.
Chest_Rockwell is offline   Reply With Quote
Old 02-20-2006, 10:01 PM   #2
Stu Olson
Stu Olson's Avatar
Fluid quantities....
http://www.stu-offroad.com/misc/maint.htm
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 02-21-2006, 08:54 PM   #3
Chest_Rockwell
Thanks Stu
Old 02-21-2006, 09:37 PM   #4
fried_gold
I thought you filled to the hole with the rockcrushers as well.. Do they not have instructions or anything?
fried_gold is offline   Reply With Quote
Old 02-22-2006, 01:02 PM   #5
CAJUN_YJ
oil
Hey Stu, I have a rubi and I'm fixin to replace my front and rear diff oil over to Royal Purple. I know It takes 75-140, but is there an additive LSD in the D44?
CAJUN_YJ is offline   Reply With Quote
Old 02-22-2006, 01:28 PM   #6
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
Any synthetic oil will already have the LSD fricition modifier necessary read the bottle it will tell you its in there
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
www.offroadoverstock.com
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline   Reply With Quote
Old 02-22-2006, 04:45 PM   #7
05LJ
If the new cover increases the volume of the housing then filling it with the factory fill amount may not be enough. Did you mark the side of the housing at the level equal to the bottom of the fill hole for the stock cover? If so fill the differential up to that level regardless of the amount it takes (relative to the factory fill quantity). Many of the aftermarket differential covers have the fill holes located higher on the cover so that you can rotate the differential housing to adjust driveline angle. Thus you can either end up filling the differential up too much (if you haven't rotated the diff.) or, as already stated, if the cover allows for an increased fluid volume and you just add the factory fill amount you may be too low. Just my 0.02
05LJ is offline   Reply With Quote
Old 02-22-2006, 05:58 PM   #8
willy peter
Rubi's don't need an additive for their LSD's. But yes the RP does have it anyway.
Steel Blue 2001 TJ Sport
D44/D30 with 3.73's/31x10.5 Kumho AT's on stock canyon's/Rhino-lined interior/Alpine 9856 Headunit with Infinity speakers/Teraflex disco's/Blacked out headlight bezels/Removed front flotation devices!
Planning on more, just saving up the cash.
willy peter is offline   Reply With Quote
Glock Forum
