Quantcast Differentials - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Differentials
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 02-23-2005, 09:06 PM   #1
JeepKidd
Differentials
What makes the Rubi soo special? the locking diffs? i dont know what they do. What does an 98 SE have, differential wise? AND....how much would it be for front and rear locking differentials.
[B][COLOR=Navy]Hurricane Jeep Club Member # 4[/COLOR]
[COLOR=DarkRed]Under 18 Jeep Club Member # 5[/COLOR]
[COLOR=DarkGreen]Green Jeep Club Member # 127[/COLOR][/B]
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Hella 500 Driving Lighs
2 Delta Fog Lights
JeepKidd is offline   Reply With Quote
Old 02-23-2005, 09:10 PM   #2
MattTheMudder
Ask Mr. Owl
MattTheMudder's Avatar
Originally Posted by JeepKidd
What makes the Rubi soo special? the locking diffs? i dont know what they do. What a 98 SE have? AND....how much would it be for front and rear locking differentials.
The Rubi comes with a few pieces of off road equipment, like front and rear Dana 44's, ARB air lockers front and rear, an NP241 4:1 t-case, some rockers (people often ditch these), Moab wheels (backspacing isnt practical but people seem to like em) and I'm sure there's more but I'm just goin off the top of my head and probably forgot some things.
Lockers let your tires get traction. It's like a low-tech, but much better working, off road traction control (good analogy?) When engaged, it sends power to the wheels with traction, which helps pull you over/through obstacles that would keep an unlocked Jeep spinning its tires and not goin anywhere
Edit - lockers vary in prices, those ARB air lockers go for around $700 each, Detroits can be a bit over $500, and many others vary in prices. Try to find deals, but dont get crappy lockers. There one of the most important pieces of off road equipment (for heavier off roading)
ARB lockers and OX lockers are manual, while most others are automatic. Different people prefer different lockers, so ask around. Personally I prefer ARB.
-Matt
Me fail English? That's unpossible
MattTheMudder is offline   Reply With Quote
Old 02-23-2005, 09:13 PM   #3
JeepKidd
is there any that you would recommend? how much would it be?
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Delta Fog Lights
Old 02-23-2005, 09:13 PM   #4
DLoweinc
the SE model is the 4cylinder TJ, it has 4.10/4.11 gears, not sure about air conditioning
the rubicon doesn't come with ARB air lockers, just some brand of air lockers. I'm sure someone knows who actually makes the parts, but it isn't ARB.
98 Grand Cherokee... Jack Stands, no front axle... Working seat belts!
DLoweinc is offline   Reply With Quote
Old 02-23-2005, 09:15 PM   #5
JeepKidd
haha, sorry, i fixed it. i meant what differentials does the SE have.
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Delta Fog Lights
Old 02-23-2005, 09:17 PM   #6
MattTheMudder
Ask Mr. Owl
It isnt ARB? Didnt know that, learn somethin every day
-Matt
Old 02-23-2005, 09:19 PM   #7
bigjohnwhodatis
Depends on your application, front/rear, axle, etc.; and your budget. You can go from right around $200 per axle to probably $700-$800, and that's if you can install them yourself. Your best bet (assuming some things) would probably be a lockrite/right in the front D30.
2" RE BB/Tera 3" Front Coils
1"BL/MML
33x12.5 Dunlop Radial Mud Rovers
Warn M8000
Jeeperman Rock Sliders
Big dreams and a little wallet
bigjohnwhodatis is offline   Reply With Quote
Old 02-23-2005, 09:20 PM   #8
MattTheMudder
Ask Mr. Owl
Since the SE only comes with a D30 front and D35c rear, it's open diff. The Rubicon is the only TJ that comes with lockers from the factory. Need to buy lockers aftermarket. Some D44's (dunno year) had a lsd, but you dont hafta worry about that in an SE
-Matt
Old 02-23-2005, 09:22 PM   #9
JeepKidd
soo, im kinda dumb with all this: a D44 is a differential?
just tell me this
what would be a fairly cheap, but quality way to get locking differentials.
are they worth it?
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Delta Fog Lights
Old 02-23-2005, 09:33 PM   #10
JeepKidd
So ARB manual locking hubs?
those would be good?
are they different (better?) then differentials?
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Delta Fog Lights
Old 02-23-2005, 09:37 PM   #11
MattTheMudder
Ask Mr. Owl
just tell me this
are they worth it?
Naw, a D44 is an axle. If you dont have a locker, you've got an open diff. If you have a locker or an lsd then you're locked and loaded (not so much for the limited slip, they're no substitute for a locker)
Lockers are definitely worth it if you're into moderate to heavy off roading. I like ARB because they're manual lockers, but they are really up there in price.
-Matt
Old 02-23-2005, 09:41 PM   #12
MattTheMudder
Ask Mr. Owl
Manual lockers allow you to engage or disengage them by air line (ARB) or a manually operated cable (OX) They help because you can either engage them for traction, or disengage them and leave it in open diff. They help on street because there arent any negative side effects of having lockers
Automatic lockers, like Detroit, are always working. This means that on the street, they change the handling of your Jeep and loud clicking can be heard when you corner. You'd have to adjust your driving style a bit, and they can never be turned off.
If you go with automatic lockers, I recommend Detroit. If you go with a manual locker, I'd say get the ARBs.
-Matt
Old 02-23-2005, 09:45 PM   #13
bigjohnwhodatis
I'm not exactly what you're asking here... but I'll take a shot. You're stuck with differentials, so don't throw them out just yet But if you are referring to locking hubs versus locking differentials, locking the differential is what you are talking about, there's a decent explanation above of what the function is, basically locking both sides together so that they turn at the same rate versus the side with the least traction getting the power, as is the case in your currently open differential. And I wouldn't worry about the locking hubs until we've fully mastered the differential concept
ARBs (air-actuated differential lockers) are good, that's exactly what I was referring to earlier in the upper end of the price range I mentioned.
1"BL/MML
Warn M8000
Old 02-23-2005, 10:11 PM   #14
JeepKidd
ok. thanks alot
ive got to start saving again.
im just going to install my BB that i just got in and be happy with that for a few months.
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Delta Fog Lights
Old 02-23-2005, 10:15 PM   #15
gmbtj
if you want a cheap but good locker, get a lunchbox type locker, like the powertrax or aussie locker for the front. You and I both have the dana 35 rear, so dont put to much money in it. I myself, plan on moving to a 8.8 or 9 inch when it comes time to regear and put in a rear locker.
Gun Metal Blue Jeep Club Member #1
Low Output 4 Cylinder Jeep Club Member #1 (President)
1999 Four Banga Wrangla - NO MORE!!!! -Going in 4.6L Stroker - TF 727 - Dana 300 HD
Teraflex 3T w/ OME's on 32" BFG M/T's
AtoZ Yaffy Style rocker guards l Tuffy Series II Security Console l Zirgo "S-Blade" electric fan l PSC Trail corners w/ LED's l Hella 500's l Expensive Sound System
gmbtj is offline   Reply With Quote
Glock Forum
