Differential vent tube keeps leaking - JeepForum.com
post #1 of 16 Old 03-23-2008, 08:14 PM Thread Starter
Whipper Snapper
After installing a new ARB locker in my Dana 44 rear-end my vent tube keeps spitting out oil after a couple hundred miles. The diff housing was notched during installation to allow oil to drain from the axle tubes to the diff. Any advice is appreciated.
/l ,[____],
l- -L-OlllllllO-
()_)-()_)--)_)
RE 5.5 lift, ARB 4.88 lockers, 35's, skids/armor/recovery & the usual female in tow.
C'ya on the trail.....
Whipper Snapper is offline
post #2 of 16 Old 03-23-2008, 08:23 PM
Benderff
Benderff's Avatar
Did you put an aftermarket cover on? Some covers have a higher fill port allowing more fluid when you fill it. Then it burps out.
Benderff is offline
post #3 of 16 Old 03-23-2008, 08:28 PM Thread Starter
Whipper Snapper
Yes I did replace the stock diff cover which may have caused the problem. Thanks for the reply
/l ,[____],
l- -L-OlllllllO-
()_)-()_)--)_)
post #4 of 16 Old 03-23-2008, 11:01 PM
04WranglerX
04WranglerX's Avatar
Yeah, my money's on too much oil in the diff.
04 Silver Wrangler X
Rubicon Express 4.5" SF, RE Monotubes
AA SYE, Tom Woods DS
35" Yokohama Geolanders on black rock krawlers
Dana 44 rear, ARB air locker, cromo shafts, Dana 30 front, 4.88's front and rear.
04WranglerX is offline
post #5 of 16 Old 03-24-2008, 06:49 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2 thats the problem i had with my riddlers. it would overflow for about 10k miles
pull off the breather cap and clean it well with some brakes parts cleaner and let it dry (little plastic thing on the tip of the breather hose, up by the gas tank fill hose inside the fender)
mine was clogged with 1" of dirt and junk - once the oil starts leaking out, everything sticks to it
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 16 Old 03-24-2008, 07:54 AM
yellj
How big of a notch was ground in, I found the recommended notch did not allow enough oil flow, had to go back in a second time and widen it. Not a big deal to pull the locker once set up, just keep track of your shims when you pull it. I still get occasional puking, not much, because of overfilling, but because of the angle I still fill my Rockcrushers close to the top, only get the puking when I have extend highway drives.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #7 of 16 Old 03-24-2008, 08:21 AM
slate210
From what I recall, the D44 only requires 2 quarts of gear oil, regardless of the height of the fill plug. Not sure if a locker or notching will change that.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member
- Some mods...
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline
post #8 of 16 Old 03-24-2008, 08:35 AM Thread Starter
Whipper Snapper
I really appreciate all the input. I did not notice any puking until I drove the 300+ miles from Moab to Denver last Saturday.
/l ,[____],
l- -L-OlllllllO-
()_)-()_)--)_)
post #9 of 16 Old 03-24-2008, 09:40 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'm not an ARB Air Locker owner but I could swear that there's a specific ARB-recommended fix for this issue. It also seems that the latest version of the ARB doesn't have this problem... all I'm saying is that it may not be an overfill problem. Don't ask me for more details, I've already said more than I know for sure.
Gone on vacation until August 25.
Jerry Bransford is offline
post #10 of 16 Old 03-24-2008, 02:57 PM
yellj
Jerry, the recommended fix from ARB is to grind in a drainage slot in the housing to allow for proper oil flow, that is their fix for their latest locker. Here is the link to their fix, I found it not to be enough, you can always call their tech support is fantastic.
http://www.arbusa.com/alac/alsp/5-11.pdf
yellj is offline
post #11 of 16 Old 03-24-2008, 03:34 PM
kizer
kizer's Avatar
My Super35 was drilled from what I recall talking to the installer.
1600+ Write-ups, and more
kizer is offline
post #12 of 16 Old 03-24-2008, 03:45 PM
Jerry Bransford
Administrator
Awesome, that explains it very well. Thanks!
post #13 of 16 Old 03-24-2008, 08:32 PM
yellj
10-4, the ratio of your help to where I can contribute is about 50 to 1 (with you ahead).
yellj is offline
post #14 of 16 Old 03-26-2008, 09:40 AM Thread Starter
Whipper Snapper
Great info gentlemen, see you on the trail
/l ,[____],
l- -L-OlllllllO-
()_)-()_)--)_)
post #15 of 16 Old 01-02-2009, 08:46 AM
Scotch740
Scotch740's Avatar
That link isn't working anymore here is the new one. I guess they are the same.
http://dedq15.mindfly.com/uploads/PD...uides/5-11.pdf
If anyone has any pictures of the slots they put in I would be interested to see them.
Also anyone know what model numbers or dates of ARB this is an issue with? I just had a used ARB put in my D44 and its spitting fluid out the breather in addition to a whine on deceleration. Which I hope is just from breaking in.
Scotch740 is offline
Gear oil leaking from vent tube on rear axle bradyman1 YJ Wrangler Technical Forum 10 02-16-2008 01:02 PM
Axle lube leaking from vent tube. onlyone TJ Wrangler Technical Forum 8 01-30-2007 05:47 PM
gear fluid leaking out of vent tube? okeefe11 TJ Wrangler Technical Forum 9 02-07-2006 04:51 PM
Differential vent line.....? peanut YJ Wrangler Technical Forum 1 10-15-2005 10:33 AM
Need help with extended differential vent hoses -D- YJ Wrangler Technical Forum 4 07-15-2001 08:36 PM
