Differential Service 15,000 miles - JeepForum.com
post #1 of 21 Old 01-24-2009, 11:25 AM Thread Starter
WranglerMB
Just got back from my local Jeep dealer for a routine 15,000 oil and air filter change and was informed that I need a recommended differential service at a cost of $500. Typically I follow the service manual for maintenance and there is no mention of a differential service at 15,000. Is this service really required? I've a 2006 LJ.
Thanks..........
WranglerMB is offline
post #2 of 21 Old 01-24-2009, 11:32 AM
2jhanna
early to me, if you have not been in water. also very high $$.
you can do it yourself for about $20-25 per axle. but, then again, you can also do an oil/filter change yourself for cheaper $$ (unless you got it almost free).
jhanna
denton county, tx
2jhanna is offline
post #3 of 21 Old 01-24-2009, 11:39 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Thanks..........
To remove 2 differential covers, drain, clean,reseal and fill?
GOLENJEEPTJ is offline
post #4 of 21 Old 01-24-2009, 11:40 AM
vtx531
I think it says every 12,000 miles in my manual. $500 is way too much though. It's not that critical though, most people never change this for the life of their trucks and seem to be fine. I do mine once every summer...cause I get bored and I like wrenching on my Jeep.
vtx531 is offline
post #5 of 21 Old 01-24-2009, 11:41 AM
RVA_TJ06
See what they do at the dealership (from someone I knew that worked at Jeep) they actually just suck out the fluid.. and charge you a lot of money.
Best way to do it is yourself.. But in the service manual it says to do it every 12000 miles. I think it's really early.. but I'm just telling you what it says.
Beat me to it.
Finally paid off...
RVA_TJ06 is offline
post #6 of 21 Old 01-24-2009, 11:42 AM
design311
Do it yourself and save your money. Takes an hour tops.
05 Rubicon - 3.5" RE, Currie control arms, 1.25" JKS BL, 1" JKS BMML, 35" Xterrains, Ramsey Patriot 8000
1976 CJ7 ground up resto in progress...
Firefighters Jeep Club
design311 is offline
post #7 of 21 Old 01-24-2009, 11:43 AM
vtx531
I just got one of THESE for my birthday and a 5 gallon bucket of 80w90. I will be a diff changing maniac now lol.
vtx531 is offline
post #8 of 21 Old 01-24-2009, 12:24 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I did my diffs at 30k, they were well overdue. 15k sounds about right, but don't pay the dealer $500. go to a local 4x4 shop - mine charged $180 for both axles w/ friction modifier for the rear. Don't forget to have them add friction modifier to the rear D44 in your LJ, which is needed for the Trac-Lok!!! I used that opportunity to upgrade to some Riddler Diff covers because it was included in the labor charge
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 21 Old 01-24-2009, 12:42 PM
commodore_dude
commodore_dude's Avatar
I haven't changed my diff fluid yet and I'm about to hit 24k miles, the service manual just says you need it if you've been towing, etc... my Jeep's mostly a commuter and has only very rarely done a water crossing, so I figure I don't need this "optional" change.
2006 Rubicon Unlimited
1998 Buick LeSabre Custom
commodore_dude is offline
post #10 of 21 Old 01-24-2009, 01:29 PM Thread Starter
WranglerMB
Beat me to it.
You're right, it does say replace the fluids at 12,000 I bought it used with 13,000 I didn't look back in the schedule although it does say required if subject to heavy loading and or towing. I hadn't planned on giving those criminals a dime (giving them enough in a bail-out) probably do it myself with a bit of research first, wasn't aware of friction modifier for Trac- Loks.....thanks for all the tips..... love this forum
post #11 of 21 Old 01-24-2009, 01:38 PM
AKTJ
Diff fluid change
Do a search on this site for diff service and you will find links to step by step instructions on how to do it yourself. I had never changed diff fluid before but by using the info from people here I was able to do it myself and save alot of money and have the piece of mind that it was done correctly. If you use a good quality gear oil like Royal Purple (the one I used), Amsoil, ect. they have the friction modifier already in them. Just mtc glad I took the time to do it and am now more confident about doing other repaires and maintnance.
AKTJ is offline
post #12 of 21 Old 10-12-2010, 05:25 PM
djkoder
2009 TJ Wrangler
My dealer recommended the same service at 15000. But there price is $280
djkoder is offline
post #13 of 21 Old 10-12-2010, 06:06 PM
mattlock1983
mattlock1983's Avatar
I can't believe nobody has suggested to check stu olsen's website. He has step by step instructions with pictures on how to change diff fluid. The Instructions are so simple to follow, a child has done it. It's practically free (compared to 500$) to do it yourself and it only requires one tool, a 1/2" crecent wrench. If one is afraid to apply the rtv gasket by oneself, there are lube locker gaskets to be had online that make the job a snap. If one has a rubicon, the diffs have a drain plug allowing changing of the gear oil without even removing the diff covers.
mattlock1983 is offline
post #14 of 21 Old 10-12-2010, 07:16 PM
chris142
Mine was nasty grey @ 34K when I changed mine. $500 is highway robbery though. You can easily do it yourself for under $50 per axle even if you use some super dooper oil.
chris142 is offline
post #15 of 21 Old 10-12-2010, 07:53 PM
unlimited4x4
4x4xplor has a great write up too. I used it this weekend. I can't believe they want $500 for this. What a rip off.
4x4xplor.com - Jeep TJ Wrangler, JK, CJ and XJ Cherokee Write-Ups
Look under the tech write ups. He has how-to's for a majority of the basic maintenance on your TJ.
A wealth of info on the site.
05 Unlimited 4x4
I don't want to take Mommy's car. It doesn't have sky in it like Daddy's. - CJsPerson
unlimited4x4 is offline
10k miles...what to service? Polecat TJ Wrangler Technical Forum 4 09-21-2007 07:24 PM
12K Miles Service? Jeep_Maniac TJ Wrangler Technical Forum 1 03-17-2006 06:52 AM
Differential lube every 15k miles? Westy TJ Wrangler Technical Forum 14 04-24-2005 03:06 PM
differential service? thetjkid TJ Wrangler Technical Forum 7 10-06-2004 02:36 PM
Differential service at the dealer!!! Rogue TJ Wrangler Technical Forum 4 02-08-2004 10:13 AM
