Differential Question... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Differential Question...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valuePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-26-2015, 06:19 PM   #1
jdg80129
Newbie
I have a '99 TJ with Dana 44 Axle Housings front and back, air lockers and 4:88:1 gearing. I've always wondered what is the very best lubricant is...any thoughts?
jdg80129 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 09:18 PM   #2
2jhanna
I think your making it harder than it is.
Any approved GL5, 80/90 weight should be fine.
It's been mentioned here that synthetics don't remove heat as well as non synthetics.
jhanna
denton county, tx
2jhanna is online now   Reply With Quote Quick reply to this message
Unread 07-26-2015, 09:23 PM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Why not put that information in your profile to help with future questions?...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 10:48 PM   #4
geroux
Originally Posted by Knuckelhead View Post
Why not put that information in your profile to help with future question?...
Profile police!
The information is provided pertinent to what was asked. Why the harassment?
My dogs name is Rubi
geroux is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 11:00 PM   #5
mrblaine
Wizard of Brakes
mrblaine's Avatar
If the front is a Rubi low pinion 44, I'd strongly urge you to run the factory recommended synthetic in it of your choice.
We've seen too many of them smoke the pinion bearings when run with dino and I'm not a synthetic fan with two exceptions. Front Rubi 44's and the rear axle in my 05 Dodge 3500 4x.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 11:08 PM   #6
Knuckelhead
AFSOC Retired
Originally Posted by geroux View Post
Profile police!
Typing while looking at your keyboard through a bottle again,
you truly crack me up.
Filling in ones profile helps every time someone asks a question...
Unread 07-26-2015, 11:12 PM   #7
geroux
If they are Rubi D44 with Tru-lok... 75W-140 full synthetic per the FSM.
Unread 07-27-2015, 12:32 PM   #8
Jeepsr4me
Have you figured out why the dino oil is not good enough>? I ask cause I dont know.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 04:08 PM   #9
mrblaine
Wizard of Brakes
mrblaine's Avatar
No, but I do know that having a tow truck drop a rig off at my house with a locked up front axle is not something I'd like to deal with again.
I am Savvy
Unread 07-27-2015, 04:19 PM   #10
a48jeep
Excellent to know, glad I checked out this thread.
a48jeep is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 10:25 PM   #11
geroux
If someone said use extra virgin olive oil, would you use it? It seems some folks will use what whoever has the most posts uses.
I stick to what my FSM recommends or equivalent.
Unread 07-27-2015, 10:50 PM   #12
mukluk
Of course you don't use extra virgin olive oil, the flash point is too low... stick with canola.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 11:03 PM   #13
mrblaine
Wizard of Brakes
mrblaine's Avatar
If the guy that is my warranty center tells me to use cat poo thinned with peanut butter, yes I will. He's on the hook for the repair, parts and labor so you can bet I will listen to him.
I am Savvy
Unread 07-27-2015, 11:47 PM   #14
geroux
I wasn't referring to who was warranting their work. Please re-read what I wrote.
However, if cat poo thinned with peanut butter was recommended or even extra virgin olive oil, I would have to question that and refer to my FSM.
Unread 07-28-2015, 07:32 AM   #15
mrblaine
Wizard of Brakes
mrblaine's Avatar
I read the question and since you quoted no-one, I guessed that the question was without context so I did answer it as you wrote it. Not only would I use extra virgin olive oil, I would use whatever was recommended by the guy doing the warranty on the gears he just set up.
Now, if you meant I had stock gears, stock locker, and stock axles, then I would follow whatever the owner's manual or FSM recommended as they are supplying the warranty.
Identical to the steering stuff I do for folks. I tell them what to run for PS fluid. If they decide that the FSM is more right than I am and decide to run anything but what I tell them to and burn it up, it won't be fixed by me for anything less than full price.
I am Savvy
