Differential Maintenance Suggestions? - JeepForum.com
post #1 of 3 Old 07-21-2010, 09:15 PM Thread Starter
yinzerr8
While crawling underneath the rear of the Jeep (my 06 TJ SE with ~57k miles - no lift & mostly highway driving w/ some light highway action) I noticed that my rear diff (Dana 35) seems to have oil around the gasket, in addition to the terrible rust issues.
Check the pictures
Picture 1
Picture 2
Is this something I should be concerned about? I've read through the writeup on how to service the diff's here - Jeep Axle Differential Fluid Change Service - it doesn't seem like something that would be out of my leauge, I'm just concerned about snapping off a bolt.
Thoughts?
yinzerr8 is offline
post #2 of 3 Old 07-21-2010, 09:41 PM
2jhanna
The rust pictured is not unusual. Just a little surface rust. You can wire brush and spray with black rattle can if it worries you.
Leak seems to be from cover, which can be fixed by changing fluid and cleaning rear cover and mating surface and resealing with rtv sealant.
jhanna
denton county, tx
2jhanna is offline
post #3 of 3 Old 07-21-2010, 10:44 PM
RogueSpear2023
When was the last time you changed fluids according to jeep it should be done every 24,000miles, so it's time it would be a good thing to fix. As far the cover that is normal especially if you live some where they use salt, I would just sand it down to bare metal and repaint it black when you change diff fluids. As far as the seepage that is probably do to the RTV leaking a little, once you clean, and reseal it should be fine.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
differential , maintenance , gear oil , replace , replacing , TJ
JK Maintenance waterboarder JK Wrangler Technical Forum 33 07-31-2010 04:43 PM
Differential Maintenance - Suck and Spit Method? mayberry97 TJ Wrangler Technical Forum 15 06-13-2010 06:55 PM
Differential & Xfer Case "Scheduled Maintenance" BadHammers JK Wrangler Technical Forum 7 03-10-2010 07:26 AM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 12:38 PM
2000 Mile Rd Trip - Maintenance suggestions? robisha2 TJ Wrangler Technical Forum 8 08-03-2007 03:36 PM
