Differential leak - JeepForum.com
post #1 of 10 Old 07-19-2010, 08:51 PM Thread Starter
Anthem
Differential leak
Closer look....
Could this be the axle seal..or something more ominous....
Anthem is offline
post #2 of 10 Old 07-19-2010, 08:55 PM
Hesher420
could be the diff cover, could be the pinion seal
Can you get a pic of the underside of the diff?
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #3 of 10 Old 07-19-2010, 08:56 PM
Bigworm
Looks like the diff cover or one of those bolts holding that blue bracket on. I would remove the cover, clean both surfaces, reinstall with good silicone around the cover and bolts and refill it.
Bigworm is offline
post #4 of 10 Old 07-19-2010, 09:20 PM
gilg2533
Look for oil running back from the pinion before you waste your time playing with the cover. If you do pull the cover DO NOT USE A GASKET!!! I personally would use a product called "the right stuff" (any auto parts store should have this it is a permatex product) or any rtv sealent will do.
gilg2533 is offline
post #5 of 10 Old 07-19-2010, 09:21 PM Thread Starter
Anthem
Here is a couple..I couldn't get a focal with my camera so had to use my cell...
Not that great unfortunately
Anthem is offline
post #6 of 10 Old 07-19-2010, 09:45 PM Thread Starter
Anthem
I'm a jeep noob. I've ordered a Haynes manual, but in the meantime, ...er...where would one look, if one were to look for oil running back from the pinion....you know, just for those guys that don't know....hehe...
Anthem is offline
post #7 of 10 Old 07-19-2010, 09:49 PM
wushaw
Rockin jeep
wushaw's Avatar
Looks like the diff cover is just leaking, pull cover, clean, re-seal, re-install cover, fill...be happy
wushaw is offline
post #8 of 10 Old 07-19-2010, 09:52 PM
theducksguts
first off, you need to settle down a bit. It just looks like you peeled back the cover a bit. By the looks of your gear oil it might be time for a change too. Do a search for how to change your gear oil. Get some RTV and do it up right. You should be able to do this for under 20 dollars.
second, if you think the oil is leaking from the pinion then you can replace the pinion seal. It's not difficult, you will need a breaker bar, or an impact to get the pinion nut off as it should be torqued to 170 ft. lbs.
Search feature is great. I also recommend how to sites like:
4X4explorer
Daily Driven TJ
and
Stu Offroad
best of luck to you in your inquiries.
Check out my
theducksguts is offline
post #9 of 10 Old 07-19-2010, 09:53 PM
littledevilTJ
get a lube locker.
clean the the gasket material and crap off, put the lube locker one, tighten up and your done. next time you need to change fluid, pop cover drain, then reinstall.
My OLD build thread:
Florida Specific Forum
littledevilTJ is offline
post #10 of 10 Old 07-19-2010, 10:02 PM Thread Starter
Anthem
Thanks for the advice...but seriously..
w.t.f.
Anthem is offline
differential , seal , leak , oil , TJ
Differential leak? nqlblq TJ Wrangler Technical Forum 19 06-24-2010 02:24 PM
Differential Oil Seal Leak???? Tjosh97 TJ Wrangler Technical Forum 2 09-23-2009 03:42 PM
Differential Oil Leak plowboy1690 TJ Wrangler Technical Forum 9 05-31-2005 04:01 PM
Differential leak 98tjmudslinger TJ Wrangler Technical Forum 3 03-13-2005 10:51 PM
Differential leak! 01TeeJay01 TJ Wrangler Technical Forum 4 11-10-2003 08:53 AM
