Differential leak? - Page 2 - JeepForum.com
post #16 of 20 Old 06-24-2010, 06:13 AM
TanTJ04
D-30 Axle Shaft Seal Replacement - 1
Here you go!
Originally Posted by chriswj View Post
The 4.0 is like that fat guy who will eat mac and cheese that has been on the stove for three days; eats it and wont look back!
2004 TJ X 5spd, 30-Aussie locker and Chromo'd, 44-lsd & disc brakes, 4" Currie lift, Anti-rock, 1.25" bl, UCF 1" skid & Lo-pro mount, AA SYE, JKS MML, ZJ V8 Tierod, JKS Trackbars, smittybuilt winch w/ synthetic line, Caravan fuel injectors, CAI, TB spacer, flowmaster 44 2.5", 35x12.50x15 km2, 7" fenders, uniden cb
TanTJ04 is offline
post #17 of 20 Old 06-24-2010, 06:30 AM
Zen
I used the same write-up. It's an easy job with lots of steps. If you tackle it yourself you will save lots of cash. The seals are only a few bucks for each side, you'll need new diff fluid, and a diff gasket or RTV.
When you pull the brake calliper, hang it from the shock tower with either a wire coat hanger or bungie cord so you don't strain the brake lines.
It's basically 1/2 a brake job + 1/2 a u-joint replacement + 1/2 a tire rotation, all to do 5 minutes of work. If you have any of those jobs to do at the same time, buy some beer and have a buddy hang out and help.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #18 of 20 Old 06-24-2010, 08:57 AM Thread Starter
nqlblq
Okay...
So, everywhere I read about this problem people are always out wheelin'. I was driving on a flat (very flat) I-94 for 2,000 miles. And when I got to my midway point, I started getting leakage. Since I am in-between point A and point B, is it okay to drive it? Since the original few drops, it hasn't dropped much else. The write up looks like more work than I can do with the limited tools I carry with me. And I'd hate to take it to a shop because my gues would be I'm going to be about $200 deep or so.
Thanks again everyone!
93 YJ as a kid
06 TJ out of college (RIP)
Currently Jeepless
nqlblq is offline
post #19 of 20 Old 06-24-2010, 11:40 AM
Zen
If you've got a long trip, top off the fluid and go. If the leak gets worse you might have an issue. The only real concern is running out of oil.
-Stick, splash one!
Zen is offline
post #20 of 20 Old 06-24-2010, 01:24 PM Thread Starter
nqlblq
Thanks Zen, I just checked the fluid level and it is still full so I'll keep an eye on it.
93 YJ as a kid
Currently Jeepless
nqlblq is offline
leak , differential
Rear differential leak rick95 YJ Wrangler Technical Forum 6 03-30-2006 06:36 PM
Differential fluid leak??? Ralph125 TJ Wrangler Technical Forum 3 08-12-2005 12:26 PM
Differential Oil Leak plowboy1690 TJ Wrangler Technical Forum 9 05-31-2005 03:01 PM
Differential leak 98tjmudslinger TJ Wrangler Technical Forum 3 03-13-2005 09:51 PM
Differential leak! 01TeeJay01 TJ Wrangler Technical Forum 4 11-10-2003 07:53 AM
