Differential Housing as a Jack Point? - JeepForum.com
post #1 of 15 Old 07-13-2007, 08:34 AM Thread Starter
bruker
Do you use the differential housing as a jacking point for your floor jack? I've heard that you shouldn't and that you can lift your vehicle from there. Has anyone here ever had a problem after doing so?
Sure a spoonful of Draino will clean you out, but it will also leave you feeling kind of hollow inside....
bruker is offline
post #2 of 15 Old 07-13-2007, 08:37 AM
HolidayJeep
Want pie now.
HolidayJeep's Avatar
My rear, yes, I jack it up all the time. In the front I jack from the frame since the diff. is off center. I'd bet it would be ok to use the front diff. too.
Just make sure you have some wood between the metal jack and the diff. If you scrape or mangle the diff. cover, it won't seal right and you could get a leak.
Mike
Originally Posted by Slapahoe
Not to brag, I was the valid victorian my senior year. Best and the brightest of the bottom of the barrel.
Originally Posted by War Eagle
thunderspork
HolidayJeep is offline
post #3 of 15 Old 07-13-2007, 08:38 AM
SuMeRiaN
SuMeRiaN's Avatar
Sadly I have done it a few times to get the vehicle to jackstands. I would interested to see the replies here.
SuMeRiaN is offline
post #4 of 15 Old 07-13-2007, 08:46 AM
HolidayJeep
Want pie now.
Most of the writeups I've seen (not sure about the Haynes manual) specify using the diff. as a jack point.
Mike
thunderspork
post #5 of 15 Old 07-13-2007, 09:02 AM
Burbo
Just keep in mind if the axle can't handle a floor jack on level ground how good can it possibly be on the trail? I have used the diff housing hundreds of times on a wide range of vehicles without a single issue. As HolidayJeep mentioned just take precautions if you don't want to scratch that axle, but let be real it’s a jeep and they are meant to go off road so they will be scratched eventually so why worry.
I can never find time to do it right the first time, but I always find time to do it again!
Burbo is offline
post #6 of 15 Old 07-13-2007, 09:04 AM
bobbert350
bobbert350's Avatar
its perfectly fine to do so i have been doing it from there since i had my jeep...just gotta watch out for the cover if u dont have a rock gaurd...you dont want to bend the cover or damage it
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #7 of 15 Old 07-13-2007, 09:08 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i've used the front diff when fixing sway bar link issues to get the jeep to raise off center on purpose. works fine.... just be careful, use jackstands once you get your jeep in the air, otherwise its pretty unstable.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 15 Old 07-13-2007, 09:15 AM
HolidayJeep
Want pie now.
Definitely use jack stands either way, esp. in the front. I tried using the front diff. as a jack point one time and really didn't seem very safe.
Mike
thunderspork
post #9 of 15 Old 07-13-2007, 09:18 AM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
Can you jack it up from the axel housing? I thought that was the jacking point for changing tires.....
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #10 of 15 Old 07-13-2007, 09:23 AM
erickpl
erickpl's Avatar
I usually jack it up under the control arm mounts, then insert a jack stand if I'm going to be under the TJ for a while.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #11 of 15 Old 07-13-2007, 09:29 AM
chiefkp
Can you jack the front on the axle tube so you can get a evan lift to place jack stands?
2013 JK Rubicon, 2.5 BB 35 inch pro comp M/T
chiefkp is offline
post #12 of 15 Old 07-13-2007, 09:42 AM
Combatsylvania
I always use the diffs to jack up the vehicle.. ever since i went in for a tire rotation and the saw they did it. never had a problem... I jsut make sure the tray is not on the cover..
I never have aproblem getting the forn on jack stands when jacjing from the differential either.. jsut set it down easy.
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #13 of 15 Old 07-13-2007, 09:46 AM
SuMeRiaN
SuMeRiaN's Avatar
It can ben done despite being way off center, I have done it a few times. Just make sure you get the jackstands under there asap.
SuMeRiaN is offline
post #14 of 15 Old 07-13-2007, 11:06 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
if your cover gets bent from jacking the jeep up then your screwed on your first wheeling trip
the axle tubes, diffs will both be safe to use to lift the jeep, they hold alot of weight as is you will be fine
RnEmOvr is offline
post #15 of 15 Old 07-13-2007, 11:12 AM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
I use to jack it from the passenger side axle tube, as close as possible to the diff. housing and than 6 tons stand under her asap. That's for the front. For the rear either the diff housing or the gas tank skid (if i don't have to lift it to much)
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
Front Differential Housing Canfourjeep TJ Wrangler Technical Forum 1 04-16-2009 08:05 PM
Engine Jack Point Question 95BadBoy TJ Wrangler Technical Forum 7 06-03-2007 09:36 PM
Differential housing gasket question jzmtl TJ Wrangler Technical Forum 6 04-21-2006 08:13 AM
jack point question Sixxcat1 TJ Wrangler Technical Forum 4 05-19-2004 12:50 AM
Preferred "jack" point? Shinner YJ Wrangler Technical Forum 7 08-03-2003 11:37 AM
