Differential Gear Ratio ID - JeepForum.com
post #1 of 8 Old 11-09-2007, 08:37 AM Thread Starter
lilngineer
2007 WK
Hi,
Dumb question, but how can I identify my differential gear ratios on my 99TJ 2.5L?
Thanks,
Jason
lilngineer is offline
post #2 of 8 Old 11-09-2007, 08:47 AM
frankiefire702
If it's a 5sp they would be 4:10's.
06 tj locked on 36's.
frankiefire702 is offline
post #3 of 8 Old 11-09-2007, 09:05 AM
Cooneys08JK
Cooneys08JK's Avatar
Get under your jeep and look at the differential housing on the top left corner there should be a tag and the gear ratio is stated on it....if i remember correctly the ratio is the first 3 numbers on the tag....if the tag isnt on the rear dif check the front..
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
post #4 of 8 Old 11-09-2007, 10:20 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
5 speed = 4.10
Auto = 3.73
Wheelin98TJ is offline
post #5 of 8 Old 11-09-2007, 01:52 PM Thread Starter
lilngineer
2007 WK
It is a 5-speed. So which axles they?
post #6 of 8 Old 11-09-2007, 02:01 PM
Cooneys08JK
refer to this: http://www.offroaders.com/info/tech-.../axlefacts.htm
another easy way to find out is look at your rear dif if it has a metal screw fill plug its a dana 44 if it is a plastic fill plug it is a dana 35....your front axle is definatly a dana 30...but while your under your jeep you can read the tag on the rear dif and find out what gears you have....kill two birds with one stone...
post #7 of 8 Old 11-09-2007, 02:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Front is a Dana 30, rear is a Dana 35c.
Jerry Bransford is online now
post #8 of 8 Old 11-09-2007, 02:55 PM
Wheelin98TJ
JEEP FREAK
For future reference, the "Stock TJ Specs" sticky thread has the answers to your questions.
Closed Thread
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Differential Ratio Identification Cougar59 TJ Wrangler Technical Forum 4 03-24-2006 01:27 PM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
