Differential fluid - JeepForum.com
post #1 of 10 Old 02-20-2005, 02:05 PM Thread Starter
merdas
Differential fluid
What type of diff. fluid for brand new D44 with ARB, just finished the swap and need to fill her up ?
Thanks
97 TJ
4" Full Traction long arm lift
1" MML
1" BL
Procomp 15x8
35" BFG MT
Front D30 with ARB
Rear D44 with ARB
Tera 4:1
Tera rear disc conversion
T-Max 9500 winch
LOD rear bumper/tire carrier
Currie HD steering setup
Electric fan
merdas is offline
post #2 of 10 Old 02-20-2005, 04:52 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your ARB Air Locker is really not fussy about the exact gear lube it gets. Any GL-5 or GL-6 is fine, with GL-6 being the newer improved gearlube that has slightly better specs/protection than GL-5 does. Use a lower viscosity GL-5 or GL-6 in cooler climates, a higher viscosity if you wheel in warmer climates or tow.
Jerry Bransford is online now
post #3 of 10 Old 02-20-2005, 08:05 PM Thread Starter
merdas
Thanks Jerry, what is viscosity, is there a number?
97 TJ
1" MML
1" BL
Procomp 15x8
35" BFG MT
Front D30 with ARB
Rear D44 with ARB
Tera 4:1
T-Max 9500 winch
Electric fan
merdas is offline
post #4 of 10 Old 02-20-2005, 08:15 PM
Los
The ARB recommended Lubricants Specifications are as follows:
Normal/Typical use: SAE 90 or GX90
Heavy off road use: HD 85W-140 or GX140
High temperature/Desert use: S 80W-140 or SHC 80W-140
Low temperature/winter use: S 75W-90 or SHC 75W-90
Los is offline
post #5 of 10 Old 02-20-2005, 08:22 PM
Stu Olson
Stu Olson's Avatar
ARB also states in their owner docs that the friction modifier used in limited slip diffs is perferred but not required (for improved operation).
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #6 of 10 Old 02-20-2005, 08:46 PM
Jerry Bransford
Administrator
And it is the rare GL-5 or GL-6 gear lube that doesn't already contain a friction modifier additive. The presence of the additive can be verified on the label on the rear of the bottle where it will say 'Compatible with limited slip differentials' or words to that effect.
post #7 of 10 Old 02-20-2005, 09:17 PM
Stu Olson
Stu Olson's Avatar
Yes, Jerry, I know that.....I've been reading labels for quite some time now.
The reason I mentioned it was so that folks who DO read the gear lube labels and may wonder about the friction modifier causing a problem for the ARB (most folks always preach it is needed for clutch pack LSDs) would not have to worry about it. Unfortunately, some folks never get their ARB documentation from the installer and so don't have easy access to the information. If they did, they wouldn't ask what kind of fluid to put in their brand new ARB, right?
Stu Olson
ARB Locked & Loaded
post #8 of 10 Old 02-20-2005, 11:51 PM
Jerry Bransford
Administrator
Yep Stu of course I knew you knew that, my reply was aimed at those who wouldn't necessarily know that.
post #9 of 10 Old 02-21-2005, 12:58 AM
mookarma
i didnt know that you didnt know that he knew that you knew that (stu )
mookarma is offline
post #10 of 10 Old 02-24-2005, 06:04 PM Thread Starter
merdas
I put "Castrol Hypoy C Gear Oil" SAE 80W-90. Please confirm that this is wright kind of stuff for my new 44 with ARB.
Thanks
97 TJ
1" MML
1" BL
Procomp 15x8
35" BFG MT
Front D30 with ARB
Rear D44 with ARB
Tera 4:1
T-Max 9500 winch
Electric fan
merdas is offline
differential fluid 01TJMudder TJ Wrangler Technical Forum 5 03-27-2009 02:39 PM
Differential fluid blackmax YJ Wrangler Technical Forum 5 06-27-2007 12:41 PM
Differential Fluid? nightstalker5.0 YJ Wrangler Technical Forum 3 04-05-2005 12:44 PM
Differential fluid / Transfer case fluid varsityboyz TJ Wrangler Technical Forum 4 09-07-2004 04:45 PM
differential fluid?? boozer1022 TJ Wrangler Technical Forum 7 07-15-2004 12:10 PM
