Differential Cover or glider? Which better? - JeepForum.com
post #1 of 6 Old 11-07-2008, 08:39 PM Thread Starter
SoonerE39
Planning to change the fluid in the front diff soon and was thinking about getting a new diff cover. But it seems to me you could still slam the pumpkin down on top of a rock and the front cover wouldn't do anything for you.
Then I found this glider and was wondering if this would or wouldn't work better.
http://www.quadratec.com/products/12523_200.htm
Tell me why a diff cover would or wouldn't be better than this. This is for the Dana 30 front diff
Thanks
4.0L Auto. D30/D35 3.07 gears, 1.25" Spidertracks spacers, RC 2.5" lift, 1.25" BL, 32 x 11.5 x 15 BFG MT tires, Brown Dog 1" MML, M.O.R.E Bombproof MM Brackets, Big Daddy Tie Rod, JKS Adjustable Track Bar, JKS Quicker Disconnects, KC Daylighters, Smittybuilt swing away spare tire- bumper, XRC8 Winch
Red Jeep Club #493
36,602 posts behind Jerry Bransford and getting further behind each day!
SoonerE39 is offline
post #2 of 6 Old 11-09-2008, 04:46 AM
JohnP
I was wondering about this myself. They look like they would work very well, but I've never seen anyone running them. Comments, anyone?
1998 TJ Sport
2006 TJ Rubicon
2007 KJ Liberty
JohnP is offline
post #3 of 6 Old 11-09-2008, 05:30 AM
Jeepster83
the 2 things mentioned do different things. the diff cover is a heavy duty cover that resists impacts directly to the cover. whereas the skid allows the axle to slide over the rock or whatever could potentially get you hung up. for the max in strength and protection get both.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #4 of 6 Old 11-09-2008, 07:15 AM
Krautzy
Thanks
I had one similar to that one on my YJ, and it saved my front diff both on the trail and off ! That on part was when a large chunk of concrete fell off of a construction truck going down the freeway. Off-road; it helped alot to get me past some of those low obstacles. Too bad my tie-rod took a hit though...
Krautzy is offline
post #5 of 6 Old 11-09-2008, 09:10 AM
unlblkrubi
A SOLID or Riddler diff cover will take enormus amounts of abuse why add a slider when it lowers ground clearance and will probably get you hung up on something.
Black 13 JKUR 10th Annivsary
White 13 JKUR
___________________________________________
unlblkrubi is offline
post #6 of 6 Old 11-09-2008, 09:31 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That is the RockIt by TurboCity and that's the last thing I'd pay good $$$ for. Gliders can be very good but that one isn't strong enough to hold up to anything serious. Several local guys I know used to run that exact glider but the rocks ended up ripping it right off. That particular product is just not strong enough to use in truly rocky terrain where a glider would otherwise be handy to have.
Between that and a good beefy diff cover, I'd go for the cover every time.
Thanks
Jerry Bransford is online now
Differential Cover XDS22 TJ Wrangler Technical Forum 2 10-04-2007 09:10 PM
8.8 Differential cover Tomb Raider YJ Wrangler Technical Forum 14 09-12-2006 08:46 AM
differential cover plugs CJWPDX TJ Wrangler Technical Forum 1 01-17-2006 12:58 AM
which differential cover bikerjeep TJ Wrangler Technical Forum 17 07-27-2005 03:00 PM
Differential/Glider or guard Bill01TJ TJ Wrangler Technical Forum 9 10-02-2004 08:11 AM
