post #1 of Old 02-22-2007, 09:19 AM Thread Starter
yellowismellow
Custom User Title
yellowismellow's Avatar
a different hummer intake question...
so i see many ppl do the hummer cap install and modify their intakes using buick filter boxes and whatnot. my question is, i want to keep my stock intake and modify the vent intake. could i or has anybody used the hummer intake mushroom and had it connected to the intake of the hvac system? its located right under the cowl and seems like it would have some functionality if i raised it up on top of the cowl like the intake system mod. should i do it?
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is online now
post #2 of Old 02-22-2007, 09:28 AM
None
I was thinking about that as well. Underneith the cowl, facing your grill the intake for your vents is all the way to the left. you could block off the horn piece of the stock intake and run another tube from the BACK of the stock box, through the firewall.
That way the air getting into the vent on the top of the cowl goes to supply your vent and your new intake. You could get a air scoop for the cowl to direct more air in there or just run the mushroom part and keep the cowl the way it is.
None is offline
post #3 of Old 02-22-2007, 09:47 AM Thread Starter
yellowismellow
Custom User Title
no my jeep is a 97 so the vents on top of the cowl are 3 wide and the scoops they make are ugly as all hell. way too big. i want the hummer cap for just the hvac inlet.
2006 TJ Sport
post #4 of Old 02-22-2007, 01:31 PM
None
oh ok. when you go to find the mushroom, post where you get it and how much.
None is offline
post #5 of Old 02-22-2007, 01:45 PM
bigV
bigV's Avatar
http://www.stu-offroad.com/body/cleanair/cleanair-1.htm
here's a write-up for a clean-air intake, you could probably route the hose upwards and attach it to a hummer snorkel cap, instead of the K&N as shown.
bigV is offline
post #6 of Old 02-22-2007, 11:27 PM Thread Starter
yellowismellow
Custom User Title
things that go BUMP in teh night
2006 TJ Sport
post #7 of Old 02-24-2007, 07:52 AM
bgulizia
I snagged a hummer cap from this place:
http://www.tnjmurray.com/
$42 bucks + shipping based on where you live.
-bg
bgulizia is offline
need help finding a hummer intake cap legend6009 Wrangler General Discussion 5 05-02-2012 06:55 PM
hummer cold air intake on a YJ? muddy93 YJ Wrangler Technical Forum 4 05-12-2011 08:19 PM
Hummer "style" cold air intake question SwissK31 TJ Wrangler Technical Forum 10 12-02-2009 10:10 PM
Looking into a CAI/Hummer Intake KevinR TJ Wrangler Technical Forum 6 11-24-2009 03:19 PM
hummer intake yellowismellow TJ Wrangler Technical Forum 4 11-07-2006 07:30 PM
You may not post new threads
You may not post replies
