06-27-2011, 04:05 PM
#16
You may not hear or smell anything yet but you will....
If you just slapped 3.73 gears on a 3.54 and down carrier and put the stuff back together it will not last long. What about the pinion?
Jim
03 Sport
06-27-2011, 04:09 PM
#17
swapped both ring and pinion from 3.73 on to 3.07 carrier. And 3.07 ring and pinion on to 3.73 carrier.
06-27-2011, 04:13 PM
#18
Originally Posted by Monster747
I put them on myself. Just plug and play and I did not doing any measurement. I just swap out from 1 Dana 30 to another Dana 30 and switching lower carrier to higher gear to see what happened. Just for fun.
Wow! We'll see how fun it is when that thing chews itself to pieces and sends parts all over the trail. Should make for some good video at least!
I understand you want to know why something doesn't work. That is commendable. But just putting something together "to see what happens" is an expensive experiment when it comes to gearing.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
06-27-2011, 04:16 PM
#19
Not very expensive. I pulled them out from a pick and pull and brought it home to mess around. Dana30 on Cherokee are alot in my area.
06-27-2011, 04:19 PM
#20
Wait so you can't re-gear a D30 from 3.07 to 3.73!? I though alot of people did...
Build thread. Check it. http://www.jeepforum.com/forum/f22/bamajeepman21s-build-thread-1289905/
Do you even lift bro? http://www.jeepforum.com/forum/f374/ - Jack
06-27-2011, 04:21 PM
#21
Of course you can. But you have to use the correct carrier for the gear ratio you are switching to.
NRA Member
06-27-2011, 04:26 PM
#22
Oh ok. Scared me there for a bit. I'm planning a re-gear from 3.07 to 3.73. Hopefully a new carrier won't cost to much.
06-27-2011, 04:28 PM
#23
new carrier and bearing around 100 bucks. I think spider gears can reuse.
06-27-2011, 05:02 PM
#24
when this gear setup fails, either take your Jeep somewhere and get the new gears installed or do a lot of research before you try to do it yourself again. Gear setup is not a "plug and play" thing; they have very tight tolerances and take a good deal of work to get right.
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
06-27-2011, 09:46 PM
#25
lets see what is the problem I will getting by doing this. Drove it for a week and off road few times, still feel normal.
06-28-2011, 05:41 AM
#26
Farm Wheeler
There are three critical areas in ring & pinion set up.
Pinion preload - Too much and the bearings will eat themselves for lunch. Too little and the pinion shaft is not being held in place properly by the bearings resulting in the bearings eating themselves and the pinion gear eating the ring gear.
Pinion depth - Must be right to ensure contact between the pinion gear and ring gear teeth falls in proper area for strength and wear.
Backlash - Too much and the teeth wear out too fast. Too little and you get excessive heat and the teeth wear out too fast.
With what you did you can be certain that all three of these things are wrong. The damage may not show up for a few thousand miles but I can pretty safely promise you that it will show up.
Keep in mind that free advice can frequently be worth less than you pay for it.
