Difference in fog light wiring make a difference? - JeepForum.com
post #1 of 4 Old 08-12-2010, 08:25 PM Thread Starter
joeksjeep
Ok so im getting ready to wire up my fog lights and i cant remember or know if this makes any difference to wire it the way in this diagram or to have 2 power wires from the relay instead of the splice....
Like a power wire from 87 to a light and a power wire from 87a(which is not in this diagram) to a bulb
Is there a difference in power going to each bulb or is it nill????
92 Xj 190,XXX miles needs love, and a TURBO HA!
150RwHp, 186 Lbs torque Rw, and all at 175XXX miles in my Xj
DD 98 wrangler sport 5spd 4.0 106,XXX miles
Chrysler Factory Trained Jeep technician, and A.S.E. Certified Master Tech
joeksjeep is offline
post #2 of 4 Old 08-12-2010, 10:42 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
simply put.... it would be a 'fail."
When the coil of an SPDT relay is at rest (not energized/OFF), the common terminal (30) and the normally closed terminal (87a) have continuity. When the coil is energized/ON, the common terminal (30) and the normally open terminal (87) have continuity.
so.....
if you hook it up like your talking about using the style relay you have, the wire/light the is hooked to 87a will be powered when the relay is 'off' and that one light will be on. when you 'turn on' the relay, that light will shut off and the other light hooked to 87 will turn on.
wire it like the diagram. eliminate the headache.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #3 of 4 Old 08-13-2010, 05:18 AM Thread Starter
joeksjeep
hmm ok haha did not know that the 87a was off when the relay is energized ha... Thanks for the help
post #4 of 4 Old 08-13-2010, 05:12 PM
BlueFlame
BlueFlame's Avatar
Or, get the correct relay. SPST, the one with two 87s and no 87a.
BlueFlame is offline
No ethanol does make a difference. MichelleStarr Wrangler General Discussion 27 01-05-2009 06:14 AM
make a big difference? fltj TJ Wrangler Technical Forum 15 11-14-2008 05:07 PM
What a difference tires make! GADave TJ Wrangler Technical Forum 30 02-23-2008 04:49 PM
will this make a difference?? mean90yj YJ Wrangler Technical Forum 6 04-07-2007 02:24 PM
How Much of a difference will new shocks make? Robbins YJ Wrangler Technical Forum 1 01-13-2005 02:49 PM
