difference on adjusting the links of antirock - JeepForum.com
post #1 of 8 Old 09-23-2008, 01:02 PM Thread Starter
MODUS
MODUS's Avatar
hello guys
i often see a differrent way of adjusting the links of antirocks.
i am talking about that way
the side bars are not parrallel with the tub but there are a bit higher
i wonder if there is any reason for the guys doing that?
any advantage?
thanks in advance
TJ '03 SAHARA EDITION
Thanks..
MODUS is offline
post #2 of 8 Old 09-23-2008, 01:04 PM
girly04LJ
2011 JK Wrangler
More droop without going over center maybe
girly04LJ is offline
post #3 of 8 Old 09-23-2008, 01:07 PM
mudb8
want it rite or rite now?
mudb8's Avatar
they need to be up there 10 degrees or so for proper travel
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #4 of 8 Old 09-23-2008, 01:08 PM
mudb8
mudb8's Avatar
mudb8 is offline
post #5 of 8 Old 09-23-2008, 01:14 PM Thread Starter
MODUS
MODUS's Avatar
sorry if i cant fully follow you but who can i understand if i need that adjustment?
Thanks..
MODUS is offline
post #6 of 8 Old 09-23-2008, 01:20 PM
mudb8
mudb8's Avatar
if ya have em adjusted level it'll bind before ya get full droop and the anti rock wont do it's job..
mudb8 is offline
post #7 of 8 Old 09-27-2008, 02:53 PM Thread Starter
MODUS
MODUS's Avatar
got the point!
thanks.
do i have to fab some new longer links to give that 10degre above the horizon or my stoky ar links allow that?
i am talking about the secure screw threads that will be after the new adjust ?
Thanks..
MODUS is offline
post #8 of 8 Old 09-27-2008, 03:02 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The arm is at an upward angle to prevent the link from flipping forward at full droop.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
When adjusting Autotrans links... few questions opticalwaveguy TJ Wrangler Technical Forum 13 01-20-2012 05:09 PM
Is there a difference in each side TJ front sway bar links JeepJeep31 TJ Wrangler Technical Forum 14 06-16-2009 07:16 PM
Antirock on a YJ paultyler YJ Wrangler Technical Forum 11 10-09-2006 02:26 AM
Antirock...WOW! BillR TJ Wrangler Technical Forum 31 09-21-2006 05:31 PM
antirock jeeptj97 TJ Wrangler Technical Forum 9 11-03-2004 05:01 PM
