Diff. skid plate install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Diff. skid plate install
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 02-08-2005, 07:10 PM   #1
jw98tj
May be a stupid question, but here goes. If I install skid plates on the front and rear differentials will it mess up the gaskets?
1 ton YJ on 44" Boggers
jw98tj is offline   Reply With Quote
Unread 02-08-2005, 07:30 PM   #2
WVZJ
Is it a full cover or half? If its a half cover you might be ok. I would go ahead and replace the gear oil and put a new gasket on it if it were mine.
98 ZJ 5.2, LA n Locked 35's
87 MJ, 4.0, 8.8, 32's
01 XJ 2dr, 4.0 5spd, 31's
07 Ram 2500 5.9 ctd
WVZJ is offline   Reply With Quote
Unread 02-08-2005, 07:32 PM   #3
jw98tj
Will be the half cover by Warn. I think it is 4 bolts to remove.
Unread 02-08-2005, 07:39 PM   #4
BigWaylon
tubework is cool...
BigWaylon's Avatar
just remove the 5 bolts...put the cover in place, and bolt back in...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Unread 02-08-2005, 07:41 PM   #5
BigWaylon
tubework is cool...
BigWaylon's Avatar
I would suggest buying hex-head bolts to use...1/4" longer than the stockers...
here's what my Warns looked like the day I installed them...but I sold them a month or two ago...
Greg
