#1 | |
Hairy Armgina
Diff Skid or Diff Cover?
Well, i've been scared into getting skids seeing as i've taken a few close hits under the jeep, so, i was lookin at Diff protection.
Well, i saw the Warn diff skid plates, just bolt over the bottom half of the diff. 3/16th steel, not welded but bent i guess. when i stoped over on northridge 4x4 and saw a special they had. 2 rock crusher diff covers for 129.99 shipped. well, turns out that covers for a D30 for this deal are SOLID, and cost a little more, so its 165 shipped for a SOLID and Rock crusher diff cover. which would be the better buy? the covers or the skids? it'll be about the same price either way. prolly a little cheaper for the actual covers.... whatcha think?
Andrew - Landscape architect in training. Not landscaper If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat! "One of the best ways to get yourself a reputation as a dangerous citizen these days is to go about repeating the very phrases which our founding fathers used in the great struggle for independence" - Charles Austin Beard OOoooh, it's a killin' machine! It's got everything! Like a drivin' power, big fat tires, and everything! - Deep Purple The Beast Build Thread:Marns '73 Wagoneer Thread ----- Gone but not Forgotten:97 TJs Build Up.
#2 |
I run a Rock Crusher diff cover on my D30, and I am happy with it. I was in the same boat; not sure which way to go, but then I found this one for sale on Craigs list for $45.00 in a sealed box.
06 Wrangler Unlimited Khaki, Congo Cage, D30 w/Aussie & D44 w/ Limited slip and 3.73 gears, 231HD transfer case with 2LOW and JB Conversions SYE with a Tom Woods DS. LIFT: Full Traction 4" Ultimate lift and JKS BL, Brown Dog MML. SKIDS: Jeep Medic TT and Oil Pan, Warn Gas Tank, and Rusty's Steering Box & Radiator. STEERING: ZJ steering, and PCS Steering Box. Running on 35" BF Goodrich Mud Terrains. And to ruin the look, I added Warn 6" flares to keep it legal. 99 Wrangler, 4.0L, 5-speed, 31's. Daily driver |
#3 |
Hairy Armgina
just wondering which would offer more protection, or any advantage/disadvantage to either.
#4 |
I have a Poison Spyder on my front diff. kinda expensive....
I bought a rear cover, too but I'll be damned if I can get the cover bolts out. that's fine though, since I'll be probably have a gear job done soon. you can take a look at it sometime if you want, Marn. |
#5 |
Buy the ones from Northridge. Those skids wont last long in the rocks. Plus the covers have a higher fluid fill hole so if you dont have a CV driveshaft already then when you do tilt your pinion you will still be able to get in the correct fluid. Hands down the rockcrusher/solid.
#6 |
I personally like the Riddler covers (like Crane) because there are no lips to get hung up on in the rocks. Its a little more expensive, but still reasonably priced.
http://www.rokmen.com/products/differential_protection/riddler_diff_covers/riddler_diff_covers.html Thats what I bought, haven't installed it yet, but this thing is seriously beefy.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75 and much more... Riddler torture test video Oil Filter Study Useful Axle Info Thread |
#7 |
Hairy Armgina
meh, 35 extra bucks...thats new diff oil and RTV....
#8 | ||
IX-X-XIII-XIV-XL-XLIII
Marn,
Do you have an engine/oil pan skid? Or a gas tank skid?
-Bob '98 Black TJ Sport 4.0L/Auto Trans -(O|||||||O)- my rig: http://i9.photobucket.com/albums/a95/steelman_d/Wheelin/DSC06310.jpg _____________________________________________ Quote:
#9 | |
Hairy Armgina
no gas tank yet. i'm armoring the things that have taken the most hits so far man. engine skid is the first thing, and my diff's have gotten REALLLL close to being hit on the cover. if the hits were an inch or 2 higher, i'd have been in a bad spot... On one occasion i was brought to a complete stop by ramming the edge of my diff into a rock that i hadnt seen. ![]() see my oil pan in the back ground? (manifold in the foreground).. i think that is the scariest damage so far. ![]()
#10 |
I've pesonally ran the poison spyder diff guards and ruff stuff full covers. I like the ruff stuff covers much better. Seems much beefier to me.
06 tj locked on 36's. |
#11 |
Better now than later, I always say when it comes to armor. Your diffs don't look too bad yet. I'm really gonna have to work to get the bottom bolts out of any of my covers.
Just my experience with the RockCrushers, some of the holes won't line up nicely. That makes installation a little difficult because you're trying to hold it up, while not moving it around too much so you don't ruin the RTV, so you can get the bolts in. I would suggest getting a Lube Locker gasket so you don't have to work quickly and you can take your time and maneuver the cover around to fit right. I agree with frankiefire, the Ruff Stuff covers are some of the strongest ones I've come across. If OX doesn't come out with their 8.8 locker soon, I'm going to be getting one for my rear. |
#12 | |
Hairy Armgina
#13 |
It depends. Some people have had to bore some holes out, others have been able to get it on there by just shifting it around. Either way it's a PIA.
I moved mine around too much when I did it, and the RTV didn't set right. I had a miniscule leak that went unoticed for a couple weeks. Long story short, the fluid ran low and I burned everything up inside. End product was an 8.8 though, so it's not all bad. I would just suggest a gasket so you can take your time and move it around when installing it. |
#14 |
Ill vote for new diff covers... (i dont have either, yet) but they increase the volume, so you have more diff fluid in there, so it would run cooler..
just my 2 cents
2006 TJ SE - Does what I want it to do. [URL="http://www.combatsylvania.com"]http://www.combatsylvania.com[/URL] |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
