Quantcast Diff Fluid Change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Diff Fluid Change
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 09-28-2007, 01:52 PM   #1
ianschrd
Diff Fluid Change
I'm doing a diff fuild change on my D35 rear end and I'm worried I may break the plug. I was thinking I should pull off the cover and then take the plug out after it is off. Any advice would be great.
Thanks
Let the spending begin!!! Membership to Jeep Forum,
Yellow Top Optima, 4" Super Lift, A to Z Rear Bumper,
KC Windshield Light Brackets, Warn Front Bumper,
Warn 9.5Ti Winch, 48" High Lift Jack, KC Fog Lights,
130W KC Daylighters, Gibson Cat-back Exhaust, Kargo Master Safari Rack
ianschrd is offline   Reply With Quote
Old 09-28-2007, 01:54 PM   #2
jeeptillidie
If you are worried about breaking it then take the cover off first. Its not a drain plug anyway so you are going to have to take the cover off to drain it anyway.
jeeptillidie is offline   Reply With Quote
Old 09-28-2007, 01:54 PM   #3
UnsanePyro
The D35 should have a rubber plug. As with anything though, always pull the fill plug first, before you drain anything.
I just pop mine out with a flathead screwdriver
UnsanePyro is offline   Reply With Quote
Old 09-28-2007, 01:55 PM   #4
jeeptillidie
Why????????
Old 09-28-2007, 01:57 PM   #5
mdm
Farm Wheeler
Originally Posted by jeeptillidie
Why????????
Why what? ....
mdm is offline   Reply With Quote
Old 09-28-2007, 02:01 PM   #6
jeeptillidie
Why is it important that he pull the fill plug before taking the diff cover off? I can see if it was a tranny or TC but if hes afraid of it breaking or ripping then it would be much easier IMO to push it out from the inside.
Old 09-28-2007, 02:43 PM   #7
BradG
I usually just use a pair of plyers to pull it off. It's a strong plug.
2003 TJ X Silver | 31x10.50x15 BFG A/Ts | 10k front tow hooks, factory rear tow hook | 2" coil spacers | Cobra 19 with RatShack 102" stainless whip on an Arizona RockyRoad tire carrier mount | Kilby Steering Box Skid | AtoZ Fabrication Rock Sliders | Olympic Slider Rear Bumper w Receiver | Skid Row Engine/Oil/Tranny skid (still sitting in my living room)
BradG is offline   Reply With Quote
Old 09-28-2007, 03:00 PM   #8
svt_4_me
1997 XJ Cherokee
just in case you drain the fluid and then can't remove the fill plug. then you have no way to fill it back up and you can't drive anywhere...
svt_4_me is offline   Reply With Quote
Old 09-28-2007, 03:31 PM   #9
UnsanePyro
Yeah, what happens if he rips it or something trying to get it out and can't get another one for a couple days? It's just a good thing to always do IMO.
Old 09-28-2007, 06:57 PM   #10
Chris @ GATR
If you are afraid of messing up the little rubber plug, I am not sure you are confident enough to change the gear oil.
Got ignorance? Please see below.
[QUOTE=kd4yor;4763909]Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).[/QUOTE]
Chris @ GATR is offline   Reply With Quote
Old 09-28-2007, 11:03 PM   #11
2jhanna
most auto parts stores have the rubber diff plugs for only a couple of bucks. why not by a new one, as a spare, when you get the gear oil ?
jhanna
denton county, tx
2jhanna is online now   Reply With Quote
Glock Forum
