diff fluid - better to under fill then over fill? - JeepForum.com
post #1 of 3 Old 04-20-2006, 06:13 PM Thread Starter
4lo2.5
I just changed my rear diff fluid and was wondering if its bad to put too much in. i have the d35 and was wondering how much should be put in it. i filled it up until it started to come out. i took it for a drive and removed the cap and some fluid came out. should i just keep the cap off and let what comes out drain in teh pan?
4lo2.5 is offline
post #2 of 3 Old 04-20-2006, 06:33 PM
padkisson621
thats all you need to do is fill it until it starts coming out and you are good.
padkisson621 is offline
post #3 of 3 Old 04-20-2006, 07:22 PM
bryris
Better to be overfilled than underfilled though.
bryris is offline
ox locker fill plug size and fill level? brinoff YJ Wrangler Technical Forum 1 06-14-2010 08:18 AM
diff fluid fill after RE lift ekoms TJ Wrangler Technical Forum 9 08-24-2008 08:48 PM
Why is the front fill lower than the rear fill on my D44s? TheTwins TJ Wrangler Technical Forum 6 09-19-2006 01:26 PM
Diff fill question Torquemeister TJ Wrangler Technical Forum 2 01-28-2006 08:32 PM
Fix for a leaking diff fill plu? jeepinarkansas YJ Wrangler Technical Forum 1 03-02-2002 06:56 PM
