Diff cover hitting gas tank skid - JeepForum.com
post #1 of 8 Old 08-21-2005, 05:51 PM Thread Starter
UCTJ
UCTJ's Avatar
The diff cover on my 8.8 (Blue Torch Fab cover) is hitting my gas tank skid. I have a Skid Row skid, which just covers the OEM skid plate. The best I can figure for now is to just remove the Skid Row skid, and see if there is enough room between the two.
The diff cover is very very large, and may also contribute to the close proximity of the the two. This gas tank skid doesnt give any addition clearance like a Kilby skid does, but I was thinking maybe I could just tuck it up farther b/c I do have a 1.25 body lift. Either that or just section out an area of the Skid Row skid with a grinder to allow room between the diff and skid...what do you guys think?
I already added some coil spacers to try and get some room, but when I added my SYE and dialed in the pinion it seemed to move em closer. Any ideas......
UCTJ is offline
post #2 of 8 Old 08-21-2005, 08:36 PM Thread Starter
UCTJ
UCTJ's Avatar
anyone??????
UCTJ is offline
post #3 of 8 Old 08-21-2005, 09:39 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
could you grind the diff guard, or cut the skid?
I have the Tera diff cover and the Skid Row skid...and no contact...
since the area you are hitting on the skid is not likely to ever be a spot you'll hit with a rock, you could cut out a small section for extra clearance...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #4 of 8 Old 08-21-2005, 10:43 PM Thread Starter
UCTJ
UCTJ's Avatar
big waylon....yea I think I am goin to cut out a section of the skid....first Im gonna drop the skid plate and see if it'll clear the stock skid...then either try and tuck the tank up more...and/or section that area of the skid....hopefully it'll all work out...thanks for your input
UCTJ is offline
post #5 of 8 Old 08-21-2005, 10:44 PM
igofshn
Locked @ both ends
igofshn's Avatar
That is a very common problem when you rotate the pinion. You might have to put on adjusable lowers and move the axle a tiny bit in.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #6 of 8 Old 08-21-2005, 10:48 PM Thread Starter
UCTJ
UCTJ's Avatar
ahhhhhhh never tought bout that I have all adj CA's....so I would need to shorten em the lowers? Possibly????
UCTJ is offline
post #7 of 8 Old 08-21-2005, 10:55 PM
igofshn
Locked @ both ends
igofshn's Avatar
That would be the easiest fix.
igofshn is offline
post #8 of 8 Old 08-21-2005, 11:04 PM Thread Starter
UCTJ
UCTJ's Avatar
Cool thanks guys...I'll do that in the AM...and let you know how it went. I really appreciate your replys....
Shawn
UCTJ is offline
Inverted T steering hitting front diff cover! yippieayae TJ Wrangler Technical Forum 11 04-17-2011 08:09 PM
Gas tank skid plate hitting rear Diff - BL or Spring lift? JohnnyGP TJ Wrangler Technical Forum 5 08-27-2009 10:58 AM
JKS adj trackbar hitting DANA 30 diff cover ! jeep2008 TJ Wrangler Technical Forum 36 02-25-2009 08:49 AM
tailpipe hitting Kilby gas tank skid ROUGHSHOD TJ Wrangler Technical Forum 3 05-04-2007 11:33 AM
WTF! Took all the bolts out of diff cover...tried hitting it, spitting at it, and... JeepinYahoo TJ Wrangler Technical Forum 6 07-23-2006 09:02 PM
