Quantcast Didn't want to hijack another thread...but... (Driveshaft length for TT) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Didn't want to hijack another thread...but... (Driveshaft length for TT)
Old 02-09-2009, 07:03 AM   #1
wrangler2007
With the current mods that are in my sig, if I were to go with a TT would the driveshaft need to be lengthened or just adjust the UCA's?
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 02-09-2009, 08:46 AM   #2
mrbillbrown
It may depend on the TT. I put a Rokmen TT on before my RE 4.5/3.5 springs lift. The Rokmen raised my t-case 2.5", then the lift added approx 4-4.5" giving me about 6-7" of total t-case lift. When I measured for my custom shaft after my lift install it was only 1/2" longer than what RE recommended as an "off the shelf" CV shaft listed on some of these websites. What I'm saying is RE listed 26.5" for a short arm lift for my LJ Rubi. I measured 27". So I probably could have bought off the shelf and just adjusted the control arms. I don't know how important 1/2" is. You may not need to buy a new shaft just make some minor adj and save $300. Someone here will know. Hope that makes sense. Just my experience w/my jeep
05 LJ Rubi, RE 4.5 w/3.5 springs, MT Classic II's on 35" MTZ's, Custom CV shaft, JKS BL/MML, Bulletproof Mfg bumpers F/R, Warn 9.5ti, Rokmen TT, Rokmen Merc sliders
mrbillbrown is offline   Reply With Quote
Old 02-09-2009, 10:21 AM   #3
wrangler2007
Thanks, anyone else?
Other Vehicles:
Old 02-09-2009, 01:19 PM   #4
wrangler2007
bump to top
Other Vehicles:
Old 02-09-2009, 01:26 PM   #5
emev0l
Your LJ has a longer drive shaft so the angle isn't as bad. Pickup trucks can run a lot more lift and still use a stock drives shaft because the drive shaft is a lot longer.
You will need a longer drive shaft, I'm sure you can sell you used drive shaft on here and get some of your money back.
You could take the drive shaft to a local shop and have them lengthen it.
emev0l is offline   Reply With Quote
Old 02-09-2009, 02:31 PM   #6
Dogman
Should cost about $85 to lengthen if needed.
Dogman is offline   Reply With Quote
Old 02-09-2009, 02:38 PM   #7
Apex
Recon death squad
Apex's Avatar
So since I put on the 4.5" RE lift and an SYE/CV if I were to go with a tummy tuck, I'd have to get my TW drive shaft lengthened? weak...
SOLDSilver 02 TJ Apex Edition. "Pandora"
3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff
IndyORV
Apex is offline   Reply With Quote
Old 02-09-2009, 04:13 PM   #8
wrangler2007
Not sure if I want to get the shaft lengthened or anything...would adjustable LCA's help more too with the UCA's adjusted properly?
Other Vehicles:
Old 02-10-2009, 07:02 AM   #9
wrangler2007
anybody???
Other Vehicles:
Old 02-10-2009, 07:44 PM   #10
wrangler2007
bump to top
Other Vehicles:
Old 02-10-2009, 10:23 PM   #11
mrbillbrown
I can't believe somebody hasn't chimed in yet. I don't think anyone should have to buy a longer shaft when they get a TT. I only needed 1/2". How can 1/2" make that much difference? Do we really flex that much that we would come apart with the extra 1/2" less of shaft due to the TT? Granted I'm not an offroad superstar but I think I would try to adj my control arms long before I would spend the cash on a new or longer shaft. imho
Old 02-10-2009, 10:42 PM   #12
wrangler2007
i'm just wondering if the CA's will be enough for this?
Other Vehicles:
Old 02-10-2009, 10:43 PM   #13
Strizzy
I was running my stock DS with a 2.5" lift. Then I installed Rokmen's TT and had to get a CV shaft from Tom Wood and adjustable UCAs.
-Steve-
2004 TJ Rubicon
OME HD springs - OME shocks - RE front/rear adjustable Superflex LCAs - Rusty's adjustable front UCAs -
Full Traction rear tri-link conversion - Rusty's quick disconnects - JKS 1.25" BL - JKS 1" MML - Nth diff skid -
Iron Rock Off Road HD tie-rod - Warn M8000 - Tom Wood's rear CV shaft - Rokmen high clearance belly skid -
Rokmen Mercenary Sliders - Rokmen engine/tranny skid - Rokmen steering box skid - Rokmen Mercenary front bumper
RIP:
2004 WJ Overland: 5.5" with front/rear long arms, sliders, skids, 32" Cooper STT's and wheeled it like it wasn't my DD.
2 motors, 2 trannies, 150k miles before I parked it.
Jeeps Going Wild
Strizzy is offline   Reply With Quote
Old 02-11-2009, 07:12 AM   #14
mrbillbrown
I don't remember how much thread was left but I think I went "12" turns or so on each of my rear uppers to get it dialed in with my TT. You should have enough CA. I have the RE 4.5 SF w/adj CA and 3.5 springs and a Rokmen TT that added approx 2.5" of height and I'm setup fine. CA length shouldn't be an issue. Just whether you need the extra 1/2" or so of DS length. Call TW and see what Josh or Tom says.
Old 02-11-2009, 07:15 AM   #15
mrbillbrown
Even better. See if some kind soul with your same RE setup and a TT would measure thier driveshaft and you can decide if you need a longer one compared to yours. My LJ may be way off for comparison. Hope I'm not making things worse
Glock Forum
