Did Sea Foam and Water Treatment..Nothing - JeepForum.com
post #1 of 24 Old 07-14-2011, 05:28 PM Thread Starter
rjt30114
I have an 04 TJ and am having a rough idle/cylinder misfire after it gets "hot". I got codes showing random misfire cylinder 1 and 2. I replaced all plugs and coil pack. Seemed to work, then it did it again. Very random, not ever time. I also removed and cleaned the throttle body. Did it again. Anyway finally decided to clean combustion chamber. Ran Sea Foam..No smoke!! Ran a full cup of water SLOWLY through throttle body. Still nothing, not even water coming out of exhaust. Any ideas on idle issues and why it seems that we got no "expected" results after either of the two techniques?
rjt30114 is offline
post #2 of 24 Old 07-14-2011, 06:11 PM
mattlock1983
mattlock1983's Avatar
When I did the sea foam treatment I also did not get any smoke. The can even told me to expect that "exhaust fumes will be extreme". I was bummed because I had been looking forward to smoking out the neighborhood with the "extreme exhaust fumes".
2004 Rubicon Artic Silver, Automatic
~2.5" Lift, LT285 MTR's, Currie HD steering, Currie Anti-Rock, Nth Oil Pan Skid, Kilby Steering Skid, Warn HS9500, Rockcrusher Diff covers, Nth Slider rear DS skid, custom bumpers, PIAA reverse lights, Tuffy Console, Uniden PC78 elite CB, Nth TT (not installed)
mattlock1983 is offline
post #3 of 24 Old 07-14-2011, 06:12 PM
Billy
Billy's Avatar
i did the seafoam. got quite the show. lol maybe your rigs are burning clean already?
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #4 of 24 Old 07-14-2011, 06:26 PM Thread Starter
rjt30114
Any ideas on the original problems?
rjt30114 is offline
post #5 of 24 Old 07-14-2011, 06:27 PM
Necko2529
Necko2529's Avatar
He is not worried about smoke but rather a random misfiring and idling problem....
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #6 of 24 Old 07-14-2011, 06:39 PM
scottbr
2016 JK Wrangler
Bad Cam Position Sensor?
Originally Posted by -Deepskyy- View Post
We've made the world idiot proof, and now its full of idiots.
scottbr is offline
post #7 of 24 Old 07-14-2011, 06:39 PM
scottbr
2016 JK Wrangler
You gotta rev it.
scottbr is offline
post #8 of 24 Old 07-14-2011, 06:51 PM Thread Starter
rjt30114
I did rev. Let sit 30 minutes then drove..Did the water treatment too..The rough idle is so random that I cant pinpoint. Will the cam sensor be a random thing?
rjt30114 is offline
post #9 of 24 Old 07-14-2011, 07:09 PM
map93xj
I have that problem with my 93XJ. Supposely the 4.0 have a vaborlock problem due to the heat. Usually number 3 and 4 injectors. Mopar fix was to insulate the injectors with some sort of heat shield.
06 LJ rubi RE 4 1/2 sf, MT 35/12.50/15 on soft 8s, Kilby tummy tuck and engine skid, Wilderness frt and rear bumpers, Warn M8000, Cobra 75 cb, Genright sport cage, Poison Spyder Armor, Gen Right front fenders.
map93xj is offline
post #10 of 24 Old 07-14-2011, 07:13 PM
drknow90rs
I've had the same problem for years. Mine is "cyl #3 mis-fire". I've replaced the coil pack, cam sensor, plugs, fuel injectors. Still shows up every couple of weeks. In fact it did it today! (It's actually been a few months since it did it.) I just dis-connect the battery for 5 min and then it's good again for a while. It's aggravating, isnt it?
drknow90rs is offline
post #11 of 24 Old 07-14-2011, 07:24 PM Thread Starter
rjt30114
Very aggravating. Happened while we are on the top of Coal Creek OHV in Tennesee. It showed cylinder 1 and 2. I read about the insulator for #3..I guess I will have to keep trying to figure out as we go.
rjt30114 is offline
post #12 of 24 Old 07-14-2011, 07:29 PM
drknow90rs
I took it to the jeep dealer when it was under warranty and they couldnt figure it out either. (Mines a 2001 4.0)
post #13 of 24 Old 07-14-2011, 07:36 PM Thread Starter
rjt30114
Gee thanks thats give me a glimmer of hope....
rjt30114 is offline
post #14 of 24 Old 07-14-2011, 08:39 PM
drknow90rs
LOL, I wish I had better news, there! Just a regular "Ray of sunshine", arent I? LOL
Jason.
post #15 of 24 Old 07-14-2011, 08:53 PM
JPNinPA
Did you check the injectors. They could be dirty, not firing (wiring or bad) or the o ring gaskets are leaking letting air in.
Have you had the intake off? could be the intake is not seated properly.
Have you done a compression test?
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
sea foam liquid or sea foam deep creep?? HAMM YJ Wrangler Technical Forum 2 06-22-2008 10:03 PM
best treatment for soft top ('06 X) bheiser TJ Wrangler Technical Forum 21 05-14-2008 07:42 PM
smoke treatment... HAMM YJ Wrangler Technical Forum 12 05-12-2008 05:15 AM
SynPower Treatment Skeezer TJ Wrangler Technical Forum 1 01-19-2007 03:14 PM
Engine treatment Inukshuk YJ Wrangler Technical Forum 20 04-11-2005 11:27 AM
