Did I set my rear end up right? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Did I set my rear end up right?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 03-11-2012, 10:29 PM   #16
ratmonkey
Living dead mod
ratmonkey's Avatar
The last one is close.
You're probably one or two thousandths deep.
ratmonkey is offline   Reply With Quote
Unread 03-11-2012, 10:34 PM   #17
pcoplin
I'd run that, the most important pattern to get right would be the drive side.
If you mix in a touch of gear oil with the marking compound it makes the pattern come out cleaner.
98 TJ 5.9/46RE/D300
85 Wagoneer 5.2/44RE
97 F250 Powerstroke
98 XJ
pcoplin is offline   Reply With Quote
Unread 03-12-2012, 12:49 AM   #18
Timmay82
Destructive Tester!
Timmay82's Avatar
As in too deep? This is my first rebuild. I just don't want the rear end grenading on me. I I lose a few thousand miles of function that's ok. I plan on swapping axles to stronger units by the end if the year.
I seem to not get the mixture right. But with time I am sure I will get it down. I new the drive drive side is most important so this looks runnable? Everything is set cherry right now. Getting backlash and pinion preload has been getting easier now lol. Obviously. If you look at Yukons instructions it didn't look perfect either, maybe I am over thinking it?
Timmay82 is offline   Reply With Quote
Unread 03-12-2012, 11:53 PM   #19
Timmay82
Destructive Tester!
Timmay82's Avatar
It's all said in done, pending break in. Hopefully I didn't screw it up lol Thanks for all the help gents.
