Did I damage anything? (4WD Neutral + P) - JeepForum.com
post #1 of 4 Old 01-08-2009, 06:20 PM Thread Starter
TheMatrix
Hi,
It is my understanding that 4WD L should be engaged while in tranny neutral. I successfully got into it, but I couldn't get into 4WD H (to get back to 2WD). I decided to put it in P (park, obviously) to think about it, but that only resulted in a weird noise - not as nasty as "grinding", but something more along the lines of a piece of plastic caught in a bicycle spoke. I immediately shifted back into N, and was able to ram the 4WD shifter back to 4WD H.
Normally I'd just forget about it, but it's really puzzling me. Doesn't 4WD N mean both shafts are disconnected? So what was that noise I heard while in 4WD N and Park?
Everything about this Jeep is stock.
Thanks!
-TM
TheMatrix is offline
post #2 of 4 Old 01-08-2009, 06:23 PM
alexr40
mine does that when on 4WD LOW + PARK.... just sometimes....
1998 Jeep Wrangler 2.5L Turbo @11psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 35's with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
alexr40 is offline
post #3 of 4 Old 01-08-2009, 06:27 PM Thread Starter
TheMatrix
Thanks alexr40.
Is it normal for it to be difficult to get into and out of 4WD L? I've really got to ram/yank it fast, otherwise I hear grinding.
post #4 of 4 Old 01-08-2009, 06:36 PM
2jhanna
i have a 5 speed so i can't have any personal input. but, my `02 owners manual has a couple of paragraphs for auto users, even to the point that if it is hard, you have to turn off the engine to avid gear clash.
jhanna
denton county, tx
2jhanna is offline
bad vibrations in neutral hoghandler TJ Wrangler Technical Forum 2 06-29-2009 07:24 PM
Thought it was in neutral? bunkrdfool YJ Wrangler Technical Forum 9 05-03-2008 08:35 PM
Stuck in neutral BamaLonghorn TJ Wrangler Technical Forum 4 01-23-2008 11:21 AM
4wd wont go into neutral at all wegotj TJ Wrangler Technical Forum 3 11-13-2007 06:04 PM
Vibration in Neutral tomkirkland4 TJ Wrangler Technical Forum 6 02-22-2006 07:08 PM
