Did fixing one problem cause another? - JeepForum.com
post #1 of 3 Old 08-13-2010, 01:22 AM Thread Starter
tallguytim
I just replaced the EVAP system in an 02 TJ that I recently acquired. When smoke tested, the entire system looked like a fog machine, so I had to replace everything. Anywho, the check engine light is no longer glaring at me, but now my poor TJ takes a few tries to start up. The starter will turn the engine over, but it rarely fires up on the first try and sometimes takes 5 or 6 turns of the key to get going.
Has anybody had this problem? What might I want to check? I don't know if the EVAP and starting issues are directly related but it would be quite a coincidence for the second problem to appear right after the first one was fixed.
tallguytim is offline
post #2 of 3 Old 08-13-2010, 08:34 PM
wushaw
Rockin jeep
wushaw's Avatar
Cycle the key (without engaging the starter) several times and see if it starts, if so then you have a fuel issue with the check valve in the fuel pump assy in the tank or you may have a leaking injector.
wushaw is offline
post #3 of 3 Old 08-13-2010, 11:46 PM Thread Starter
tallguytim
Yeah, that fired it up. Looks like I might have to check/replace that fuel pump. Thanks.
cranking , problem , starter , tj
I really, really need help (Won't rev past 1,200 RPM after fixing no spark problem) Superjeep795 TJ Wrangler Technical Forum 44 02-05-2010 10:12 PM
Gas Gauge has never worked, need help fixing that problem! itsayjthing18 YJ Wrangler Technical Forum 4 01-11-2010 01:41 PM
Found the problem with my AC, how do I go around fixing it? usurp TJ Wrangler Technical Forum 5 03-09-2008 02:05 PM
Help fixing this problem. 03XJeep TJ Wrangler Technical Forum 3 01-26-2007 06:21 AM
Help fixing D35 Please EvilSpock TJ Wrangler Technical Forum 8 01-14-2007 07:58 PM
