did advice on suspension setup - JeepForum.com
post #1 of 4 Old 03-05-2007, 01:00 PM Thread Starter
knotcher
need advice on suspension setup
i have a 98 TJ Sport. I installed at 2.25" (it actually measures 2.25") spacer lift, with RE Monotube shocks, 32x11.5 BFG TAs and 15x10" Soft 8 wheels...i had some driveline vibes right away so i dropped the transfer case by about 1/2" (4 washers).
i still get some vibes when accelerating in 1st and 2nd. I just bought a 1" body lift with 1" motor mount lift. Can I install the motor mount without the body lift? I really don't care about the body lift to be honest. My 32's fit fine and don't rub. I don't want to lift the engine to fix the drive line vibes, and then bind up something else.
thanks in advance for the help.
knotcher is offline
post #2 of 4 Old 03-05-2007, 01:29 PM
SecondTJ
SecondTJ's Avatar
Yes.
10char
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 4 Old 03-05-2007, 01:30 PM
Dogman
Dogman's Avatar
Yes, but you have to relocate your fan shroud.
John 3:17
Dogman is offline
post #4 of 4 Old 03-05-2007, 01:59 PM Thread Starter
knotcher
yeah, the motor mount comes with that relocation hardware.
knotcher is offline
opinions on my suspension setup yarmish TJ Wrangler Technical Forum 7 10-17-2009 09:38 AM
Opinions on Suspension Setup wrangler2007 TJ Wrangler Technical Forum 0 09-01-2009 10:34 PM
Suspension setup question? Mike318_ YJ Wrangler Technical Forum 4 02-20-2009 01:55 AM
Final Setup for the suspension?? IH8ROADZ TJ Wrangler Technical Forum 2 02-29-2008 01:01 PM
Suspension setup questions atomicmoose YJ Wrangler Technical Forum 5 08-15-2006 07:24 PM
