Diamond plate rear corner owners
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Forum porn star...I guess
When you guys put your corners on, how did you make your fender flares sit flush with the plate since it sticks out like an extra quater of an inch from the body?
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay..... |
#2 |
nice ears there rat
yogi
COME TO YOGI & SUES 7TH ANNUAL PIG GIG AUGUST 14TH -16TH AT ROCK AND VALLEYS ORV PARK[FONT=Arial]2001 xj [/FONT] |
#3 |
i wear foil underwear too
my d-plate doesn't go that far down to where the fender flares meet, nor should they, in my opinion. you might be able to trim the fender, or cut the d-plate so it's not an issue.
lj
ಠ_ಠ |
#4 |
Does it matter if the corner guards were made from diamond plate or some other metal? If not, then all I did was reposition the trailing edge of the fender a bit so it would clear the corner guard. I believe I may have slotted a hole in order to accomodate that (it's been long enough that I don't remember the exact details). Looking at the fender, one can not tell it was moved a small amount. That may not work if your clearance issue isn't minor. In that case, I would trim the flare as I would have no intentions of removing the guards once the holes were all drilled and they were mounted.
#5 |
allright Stu, yer losing me here....
you repositioned the trailing edge of the fender, by slotting a hole....? did you move the whole fender? Why would that affect clearance? maybe i need more coffee... lj
ಠ_ಠ |
#6 | |
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's) RedCell Motorsports http://www.myspace.com/redcellmotorsports |
#7 |
right, yes, that much i kept up with :-)
ಠ_ಠ |
#8 |
Sorry....I meant I most likely slotted the hole in the flare, which allowed me to slightly resposition the flare and not have it contact the corner guard.
#9 |
and it didn't misshape the flare?
lj
ಠ_ಠ |
#10 |
Not that I could tell. Obivously, the amount one moves it will certainly influence the outcome.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
