Diagnostic code P0305 - JeepForum.com
post #1 of 6 Old 08-11-2005, 09:44 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
Searched, but couldn't find.... What is a P 0305 code for a 2005 TJ ?
Thanks!
Experience. It's what you get when you don't get what you want.
A beaver without a pelt is like a peacock without feathers.
Memberships: California Association Of 4WD Clubs - Friends Of The Rubicon - The Blue Ribbon Coalition
K6CKR
Originally Posted by Grape Ape
How many times have we told you . DON"T DUMP THE BODIES CLOSE TO YOUR HOME!!
HVACman is offline
post #2 of 6 Old 08-11-2005, 09:49 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
Never mind, I found it.
For Jeep error codes look here.... http://getahelmet.com/jeeps/tech/codes/
K6CKR
HVACman is offline
post #3 of 6 Old 08-11-2005, 09:53 PM
2k3r1
2k3r1's Avatar
It's a cylinder 5 misfire... but i dont need a chart to tell me that
I would guess you oughta buy some NEW plugs and wires if they are original or pretty old?
2000 TJ Sport, 4.0L, 5-spd, RE 3.5" with all 8 adj arms and adj trackbars with 35"s, D30 w/ Lockright, 8.8 rear axle, sye and CV driveshaft, M.O.R.E. 1" BL and MML, IPF headlights w/ H4 FATBOY bulbs, PSC power steering skid, rock-it man rockers, uniden pro 520xl WITH PA :)
Future mods: 4.88s and ARBs?, belly up, dif guards, Gastank Skid.
2k3r1 is offline
post #4 of 6 Old 08-11-2005, 10:06 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
2200 miles on them, but i just installed Banks torque tubes. Gotta go check the wire connections.
Would you still recommend replacing factory wires and plugs???? why?
K6CKR
HVACman is offline
post #5 of 6 Old 08-11-2005, 10:11 PM
2k3r1
2k3r1's Avatar
I was just guessing most the time i see a misfire code (8 out of 10) the sparkplug wires have excessive resistance or the plug has carbon tracking on it.
I would suggest you get a spark tester and hook it to a ground and your number 5 plug wire. If your tester sparks then you know the circuit UP TO the plug is good and the plug is bad OR you didnt have the plug wire properly secured to the plug. IF it doesnt spark, then first make sure you have a good ground THEN your going to have to work backwards to find the problem. Check connections of the wires and possibly resistance if you have a digital multi meter.
did you install the plugs and wires 2200 miles ago yourself?
2k3r1 is offline
post #6 of 6 Old 08-11-2005, 10:33 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
No, no no, The Jeep is new, with 2200 miles total. I did not instal the torque tube though. I'm wondering now if that is the vibration i was feeling this afternoon... only felt it under moderate acceleration. I thought it was from the driveline since is the first day i have driven it since my new axles were installed. Now i'm thinking that I was feeling the misfire.... hummm....
K6CKR
HVACman is offline
Diagnostic Code 21... mall0y TJ Wrangler Technical Forum 9 10-11-2007 04:56 PM
Diagnostic code 25??? Falco YJ Wrangler Technical Forum 4 08-17-2006 07:05 PM
Diagnostic code 27 gwiley YJ Wrangler Technical Forum 2 06-05-2006 08:41 AM
diagnostic code help rsoffar YJ Wrangler Technical Forum 1 08-22-2005 12:22 PM
Diagnostic code 33 (w/o AC?!?)` rwfisheriv YJ Wrangler Technical Forum 1 07-23-2002 12:36 AM
