Detroit VS Aussie EZ Locker - JeepForum.com
post #1 of 11 Old 02-19-2008, 04:31 PM Thread Starter
MickBurke
From what I've seen and heard, the Aussie is the best 'ez' locker out there. Is this correct? My other option is the Detroit, but I'm not sure how they compare. Any input is appreciated!
Mick
MickBurke is offline
post #2 of 11 Old 02-19-2008, 04:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The full-case Detroit Locker is, by far, MUCH stronger and smoother on the road than any of those non full-case lunchbox lockers you mention like the Aussie. No lunchbox locker is all that great on the road, but some are better than others. EZ-Locker is the worst, Lockrite and Aussie are tied for second-place (they are the same locker), and the No-Slip is the smoothest lunchbox locker going for the rear axle.
Are you talking about a front or rear locker? Is your rear axle the standard Dana 35c or do you have the stronger optional Dana 44?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #3 of 11 Old 02-19-2008, 07:06 PM
bigV
bigV's Avatar
I've had the detroit ez locker and now run the aussie locker in my d30 - the ez locker is poorly manufactured and I had nothing but problems with it. the aussie has been in for a couple months now and it's great, good on road manners in 2wd and works well on the trails in 4wd, I went with aussie over lockright for the price
High Desert 4 Wheelers
bigV is offline
post #4 of 11 Old 02-19-2008, 11:37 PM Thread Starter
MickBurke
Thanks guys. Sorry I should have mentioned it was being considered for the stock front dana 30. I'm expecting I'll get something when I replace the rear axle if I ever do. My trail riding is moderate, but wouldn't mind better traction in the front when off road. Thoughts?
post #5 of 11 Old 02-19-2008, 11:47 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
I had the Aussie and didn't have any issues with it. It will click when turning corners but you get used to it.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #6 of 11 Old 02-21-2008, 09:05 PM Thread Starter
MickBurke
Is this just when it's enganged, or all the time (meaning just in 4 wd or in 2 as well)? Thanks again all...
post #7 of 11 Old 02-21-2008, 09:39 PM
BYuen
BYuen's Avatar
The clicking is referred to the ratcheting in 2wd when the locker is allowing differentiation. It'll rarely ratchet up front in 4wd. I dunno about others peeps, but I truthfully can't ever hear my locker ratcheting up front unless I make a sharp u-turn or while turning into my garage. My Jeep is noisy as heck. I can't wait for MT tires haha
BYuen is offline
post #8 of 11 Old 02-21-2008, 10:36 PM
cvd
cvd's Avatar
I can hear my front Aussie when in 2WD, but don't feel it. I only hear it when the window's down and it's a tight turn.
cvd is offline
post #9 of 11 Old 02-22-2008, 12:08 AM
ChiliPalmer
As mentioned I was referring to the vehicle being in 2wd; although you will hear in in 4wd occassionally also.
Forum!
post #10 of 11 Old 02-22-2008, 06:57 AM
FLATFENDER54
FLATFENDER54's Avatar
detroit ez lockers are junk - manufactured poorly and work poorly (from personal experience)
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #11 of 11 Old 02-22-2008, 05:08 PM Thread Starter
MickBurke
Great info. Thanks all!
Detroit Soft Locker VS. Detroit Truetrac wdw TJ Wrangler Technical Forum 190 08-25-2016 06:41 PM
Dana 44. Aussie Locker Or Detroit? mitch_brown YJ Wrangler Technical Forum 5 10-23-2009 07:11 PM
aussie vs detroit ez locker for the front axle gribbles TJ Wrangler Technical Forum 17 03-17-2009 08:41 PM
Detroit tru-trac to Detroit locker elkfan2 TJ Wrangler Technical Forum 1 02-02-2009 11:57 AM
Front Locker: Detroit E-Z vs Aussie prossett YJ Wrangler Technical Forum 10 03-11-2005 03:59 PM
