Detroit Trutrac 3.07 / 35? - JeepForum.com
post #1 of 21 Old 12-14-2005, 11:19 AM Thread Starter
BEANS
BEANS's Avatar
I'm being told by Quadratec that Detroit trutrac is not made for a Dana 35 / 3.07.
is this true?
If this not true, what are the part numbers for a Detroit Trutrac for a jeep with 3.07 ring and pinon for the front 30 and rear 35?
2001 SPORT 4.0 AUTO EMPTY GAS TANK
2 1/2"O.M.E. 1"Body LIFT
33" DUNLAP'S
JSK QUICK DISCONNECTS THAT I'LL NEVER DISCONNECT
LIMITED SLIP WITH 4.11'S FRONT AND BACK
S.Y.E
7'6" SNOWAY POLY PLOW
Elect Radiator fan on a Delta control
Borla Header, Catback Exhaust By Volant 304SS
BEANS is offline
post #2 of 21 Old 12-14-2005, 11:23 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Sorry, I can't help you with your question, but I have to ask...
Why are you sticking with those crappy 3.07s?
Wheelin98TJ is offline
post #3 of 21 Old 12-14-2005, 11:26 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I agree. Onroad or especially offroad, a lower ratio is highly recommended.
It doesn't appear that Tractech makes a Detroit Truetrac for your 3.07 anyway according to their chart at http://www.tractech.com/docs/TT-List-LTPM1004.pdf
Getting
Jerry Bransford is offline
post #4 of 21 Old 12-14-2005, 11:40 AM Thread Starter
BEANS
BEANS's Avatar
Your right I should go to a 3.55 rear & front I'm running 32" tires. I was talking to Quadratec and was surprised to find out that Tractech doe's not carry a limited slip for a 3.07! What if you are running stock tires
33" DUNLAP'S
S.Y.E
BEANS is offline
post #5 of 21 Old 12-14-2005, 11:42 AM
FifteenCents
If your gonna pay the money for a locker/limited slip, you should regear at the same time.
.02
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #6 of 21 Old 12-14-2005, 11:47 AM
Wheelin98TJ
JEEP FREAK
3.55 is still not low enough.
I'd recommend 4.10, maybe 4.56 w/ a 5-spd or if you think you may go bigger in the future.
post #7 of 21 Old 12-14-2005, 12:05 PM Thread Starter
BEANS
BEANS's Avatar
I just got off the phone with Quadratec. They are very helpful.
I'm going to 3.73 gears front and rear. 32" tires are large enough for what I use the Jeep for. The trans. is a 3 speed auto. I'm putting Truetracs front and rear.
I'm on my way to pick everything up in West Chester.
What do you think?
Thanks for the help!
33" DUNLAP'S
S.Y.E
BEANS is offline
post #8 of 21 Old 12-14-2005, 12:10 PM
Wheelin98TJ
JEEP FREAK
What do you think?
Go with 4.10. You'll regret it later if you don't.
3.73 is a stock ratio that is best for 30" and smaller tires.
I have nothing against Quadratec, but you can do better for both service and pricing. You should try some of the vendors here. Some have some pretty good deals for forum members.
post #9 of 21 Old 12-14-2005, 12:18 PM Thread Starter
BEANS
BEANS's Avatar
3.73 with 32" tires will run about 2500 rpms with my automatic
4.10 with 32" tires will be runnin 2800 rpms!
As far as service I'm installing all this.
Price is close without shipping I can pick everything up.
33" DUNLAP'S
S.Y.E
BEANS is offline
post #10 of 21 Old 12-14-2005, 12:19 PM
Jerry Bransford
Administrator
What do you think?
Their recommendation to use 3.73 gearing for 32" tires is another example of just plain incorrect advice being given by Quadatrac, likely from a salesman who has little actual offroad experience. 3.73 is the most common ratio Jeep installs on TJs that come with 30" tires, not 32" tires. For larger tires than 30", you need a lower ratio and for 32" tires, I'd go with 4.10. If you think the "bug" might someday bite you and you might ever go with 33" tires, I'd go with 4.56.
Getting
post #11 of 21 Old 12-14-2005, 12:24 PM Thread Starter
BEANS
BEANS's Avatar
Ok Ok I'll go with 4.11s. I'm glad I asked. This guy is gona Sh*t when I call him back to change the order.
Again thanks for the help
33" DUNLAP'S
S.Y.E
BEANS is offline
post #12 of 21 Old 12-14-2005, 12:29 PM
Wheelin98TJ
JEEP FREAK
4.10 with 32" tires will be runnin 2800 rpms!....
2.800 RPMs at cruising speed is perfectly fine.
post #13 of 21 Old 12-14-2005, 12:29 PM
Jerry Bransford
Administrator
Good decision. Just don't let him talk you back into 3.73 as he may try to do since he'll actually have to do a little extra work to change your order.
Getting
post #14 of 21 Old 12-14-2005, 02:54 PM
T.H's TJ
T.H's TJ's Avatar
Your installing all of this?
As far as the rpms go i think my 4 banger cruises at about 3000 rpms at 70ish.
T.H's TJ is offline
post #15 of 21 Old 12-14-2005, 02:57 PM
Jerry Bransford
Administrator
Beans, if you've never installed R&P gears before, I hope you have a friend that knows how to get them installed correctly there to help guide you.
Getting
Trutrac Mykal101 YJ Wrangler Technical Forum 2 10-29-2009 02:32 PM
How difficult is it to install a Detroit Trutrac? jr1966 TJ Wrangler Technical Forum 12 08-18-2008 11:48 AM
Detroit Trutrac question - Help before I make it worse :) mylogylo YJ Wrangler Technical Forum 4 03-04-2008 10:51 PM
d35 & trutrac bobt TJ Wrangler Technical Forum 20 03-02-2006 01:46 AM
Help with Detroit Trutrac gonefishing TJ Wrangler Technical Forum 2 11-25-2005 01:45 PM
