#1 | |
Detroit truetrac S.O.S!!
The jeep is at the mech shop installing the tt at my dana30,some quick questions please help:
1)do i need to add a ltd slip additive in my dana30 since now i'll have a ltd slip in there? 2)is there a break in period?what should i do through it(drive slowly etc)?do i have to change the fluids in the dana30 after the braking in? 3)are there any installation instructions or walkthrough or sos points anywhere,cause my tt came without any instructions whatsoever! 4)anything else you'll like to advise? ![]() ![]()
#2 | |
Straight Up Fool!
Your LSD should have come with some paperwork. Raed it good for fluid requirements and break in procedures.
Off topic, but... LOL - at first I was so confused because TT on JF usually means tummy tuck
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#3 |
well it came on the post about a month ago so maybe it got lost somewhere in the huge mech shop i left it for that time,but i'm allmost certain that it came with nothing...
#4 | |
Straight Up Fool!
I would assume you need LS additive. I bet you can find out on Detriots website or at least e-mail them and they should be glad to give you that info. Sorry I'm not more help, I've never run or installed a Tru-Trac.
#5 |
You do not need any special fluids for a tru trac because they are a gear driven limted slip, there are no clutches. As far as break in I would replace the fluid after about 500 miles just to be safe. I ran one for three years running normal gear oil in it with no problems.
#6 |
Running Secretly Amok!
No additive required for a Detroit tru-trac.
#7 | |
Straight Up Fool!
[QUOTE=elkfan2;7071867]You do not need any special fluids for a tru trac because they are a gear driven limted slip, there are no clutches. QUOTE]
DUH... man did I brainfart - I forgot they were a gear type LSD! x2 on what he just said (now that my head is out of my a**)
#8 |
Drink Oregon Craft Beer!
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
When I got my TrueTrac's installed, I also re-geared. The new gears required a 500 mile break in period but to my recollection, my mechanic did not mention anything – nor have I read anything for a required break in maintenance for the TrueTrac.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather. [Edit] "Now jeepin in Oregon" [/Edit] |
#9 |
thank you guys for all the answers,any links about installation or notes about installing it?did the guys that have it remember if it came with instructions?
#10 |
I would guess that there is no break in period for the trutrac itself but you are obviously going to be installing atleast new carrier bearings so that might call for something. As far as the initial oil change, the truetrac isn't going to emit any kind of material that you are going to have to get out of there but the initial break in of the bearings possibly will. Plus anytime I have got a diff cover off doing any kind of work in there other than a normal scheduled change I always change it fairly soon just to get any contaminants out that might have gotten in there in the process.
No matter how far you go, there you are. |
#11 |
As a full carrier install unless you mechanic is a magician your gears will be wearing a slightly new pattern. I would pay attention for any abnormal noises and change the fluid at 500 miles.
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D |
#12 |
want it rite or rite now?
I must be one of those magician's you speak of... carriers changed without new gears only need the backlash reset to where it is when It's pulled apart, provided it's in spec and they usually are unless another problem was present. if It's not checked prior to tear down then you may have a problem.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#13 |
We finished installing the tt in the front and went for a testdrive,everything ok!!only thing I noticed is that the steering wheel is a little bit heavier and more willing to return to center even in 2wd and on the street.is this normal??
#14 | |
Straight Up Fool!
Yes, the rear LSD is tryimng to "push" thenvehicle straight. It will loosen up a tad and you will get used to it.
#15 |
I don't quite understand what the rear has to do with the increased force-power the steering wheel is trying to return to center?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
