Detroit Truetrac In Front And Rear Axles? - JeepForum.com
post #1 of 42 Old 05-07-2012, 04:57 PM Thread Starter
erics1019
hello i have a 2003 jeep wrangler 4 inch lift 33 inch tires dana 30 front axle and dana 35 rear axle and 4.56 gears.
i am looking at getting truetracs installed in front and rear axels i wanted to make sure that i could do that. i talked to 4WD.com and they said that i need a hub conversion in order to install a truetrac in the front axel that it would drive weird or bad without one but i have seen numerous people say its fine in front axel without hub conversion. i know the benefits of them and if the tire is off the ground and all that i live in louisiana all we do is mud here so i am fine with that.
my question is can i install a truetrac in front and rear axel of my jeep it is a DD and be fine with that or will it mess up something or the way it drives thanks!
erics1019 is offline
post #2 of 42 Old 05-07-2012, 05:07 PM
99_TJ_Wyoming
Im doing the same install without locking hubs and Im in snow and ice, all the reviews I have read say at first you can feel the TrueTrac in the front, you can tell its there but within a day or so you dont feel it anymore once you get used to the 'feeling' of it, I have never read anything anywhere that even suggests you have locking hubs, maybe someone wants to sell you some hubs Here are some reviews of the True-Tracs, its very much worth the reading.
http://www.offroaders.com/reviewbox/...hp?product=252
http://www.jeepforum.com/forum/f249/...ruetrac-771848
http://www.oramagazine.com/pastIssue...ticle=truetrac (toward the bottom is "Ongoing Tests")
There is a few to get you started. Enjoy.
99_TJ_Wyoming is offline
post #3 of 42 Old 05-07-2012, 06:10 PM
stokerdog
No hub changes needed. You will really like those TT's. Since your in LA. where I guess it dosn't snow much, why not a Detroit locker in front?
"If a law is stupid, you have to break it."
HST
stokerdog is offline
post #4 of 42 Old 05-07-2012, 06:30 PM
terpsmandan
2009 JK Wrangler
Thinking about that too. Thanks for the links.
terpsmandan is offline
post #5 of 42 Old 05-07-2012, 06:38 PM
JohnnyWhitehead
2011 JK Wrangler
Eric, where do you normally ride in LA. I am an hour north of BR and we normally ride over in Sicily Island and I have made a trip down to St Francisville for a ride once.
GEAUX TIGERS!!!!
JohnnyWhitehead is offline
post #6 of 42 Old 05-07-2012, 06:42 PM
BrianGr
BrianGr is offline
post #7 of 42 Old 05-08-2012, 09:06 AM Thread Starter
erics1019
we normally ride around st francisville and i am going with TT because people say they work very well and they are not as expensive as a locker!
post #8 of 42 Old 05-08-2012, 09:10 AM
TNeustadt
If at all financially possible, go with a selectable locker in front. It'll be much easier to steer while on the trails.
TNeustadt is offline
post #9 of 42 Old 05-08-2012, 09:12 AM Thread Starter
erics1019
i don't want to have to turn anything on or anything electrical for problems for something to go wrong. i want a truetrac always there and ready to go and it uses it self!
post #10 of 42 Old 05-08-2012, 11:13 AM
wdw
2010 JK Wrangler
I have a 2 inch lift with true tracks in both axles and 32 inch tires. For the wheeling I do, they are great.
2010 Black JK 2 Door Sport.
wdw is offline
post #11 of 42 Old 05-08-2012, 11:25 AM
IslandTJ
I've been wheeling dual Truetracs for over 5 years now and I am very happy with them. Many think that I'm locked and are surprised when I tell them that I'm not.
You do not need a hub conversion for the D30, I did not bother or even consider it. I've experienced zero ill effects in my front end despite not having the hub conversion .
I daily drive my Jeep to work and home. The Truetracs are absolutely transparent on the road IMO.
Now Jeeping in Oregon
IslandTJ is offline
post #12 of 42 Old 05-08-2012, 12:36 PM
RaggedOleMan
In the front d30 no hub conversion is required/necessary. A "locked" front will give you better off road capability, so it's worth giving a thought to the Detroit Soft Locker in the front, in lieu of the True Trac.
Regarding limited slips and one wheel off the ground: If one wheel is spinning in the mud, it's just like having one wheel off the ground. I've seen plenty of rigs with limited slip rears have trouble on the muddy/sloppy northwest trails. That said, if your trails are anything like ours, the full Detroit locker up front would be better off road, and just as invisible as the limited slip, on the road, up front.
The limited slip in the rear has excellent street manners, and will lend longevity to the life expectancy of your d35, and is helpful off road. All I'm suggesting here is to give some thought to a "locker" up front if you're going to spend that kind of money.
RaggedOleMan is offline
post #13 of 42 Old 05-08-2012, 01:23 PM
FarmerinVA
What Ragged said.
You'll love the TT in the back. As to the front, I installed an autolocker, and like it. In 2WD for normal driving, it's invisible; also, it's cheaper and easier to install than a TT. But a TrueTrac is a great choice too and would be just as invisible, plus better for your turning radius when in 4WD. See the thread in my sig for more details.
Whether to lock or do a TT in the front is a decision that you should make based not upon whether it will hurt your normal driving (it won't), but based on the kind of wheeling you do. More rocks, big stuff where you might lift a tire, and slower = locker; more mud, snow, small stuff and faster = TrueTrac.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #14 of 42 Old 05-08-2012, 02:30 PM
JohnnyWhitehead
2011 JK Wrangler
I am gonna have to try to make a few more rides down there. Let me know when you are going next and I might be able to make a trip down.
Now as far as your plans, the true-track in the back is a nice addition but I would go with a lunch box auto locker in the front. I have an Aussie in the front and it is great. It made an amazing difference on the trail after I installed it. I haven't noticed much if any turning radius loss either. Fully locked in the front is way better than sort of kinda maybe a little locked limited slip true trac.
GEAUX TIGERS!!!!
post #15 of 42 Old 05-08-2012, 03:19 PM
danb303
The Trutrac is not a clutch type LS. I had one in the front of a TJ and it worked great (my brother still has that jeep). You will never know the trutrac is in the front. I have never seen the wheel in the air spinning.
Oh, and that Trutrac has broken 2 axles... Must work pretty good!
danb303 is offline
dana 30 , front axle , true trac , wrangler
Detroit Soft Locker VS. Detroit Truetrac wdw TJ Wrangler Technical Forum 190 08-25-2016 07:41 PM
Detroit Truetrac in the front Dana 30 Victorcro TJ Wrangler Technical Forum 23 04-11-2012 03:03 PM
Detroit TrueTrac Itsnice2be TJ Wrangler Technical Forum 8 08-17-2011 09:05 PM
Front Detroit TrueTrac Noise, Help!!! Rgribbl1 YJ Wrangler Technical Forum 6 06-09-2008 03:03 PM
Detroit TrueTrac in the Rear? rkutzner TJ Wrangler Technical Forum 4 11-16-2002 07:37 PM
