Detroit Locker Dana 44 - JeepForum.com
post #1 of 2 Old 05-21-2009, 07:24 PM Thread Starter
Tuffjeeper
K I found a Detroit Locker for a Dana 44 that a guy was goona put in a Chevy front 44. I want to put it in an XJ 44.
The gear ratio is right, are there any other factors that play into it? From what I can tell as long as its a 30 Spline Detroit with the right gear ratio that's all that matters right?
Tuffjeeper is offline
post #2 of 2 Old 05-21-2009, 08:27 PM
gribbles
Yes, it should fit without any issues, if you want to double check you might call Detroit.
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
Dana 30 Detroit Soft Locker? bigV TJ Wrangler Technical Forum 31 02-15-2017 09:51 PM
Installing Detroit locker in Dana 35 herculz TJ Wrangler Technical Forum 12 12-01-2009 07:42 PM
Install Q's for Dana 30 Detroit EZ Locker bigV TJ Wrangler Technical Forum 2 10-07-2007 01:27 PM
Dana 44 with detroit locker need help tothepoint TJ Wrangler Technical Forum 9 03-20-2007 12:55 PM
Dana 30 Detroit EZ Locker UTWeezul TJ Wrangler Technical Forum 9 02-18-2007 09:32 PM
