Determining Pin Outs For TJ & XJ Gauge Clusters 96-06 - JeepForum.com
post #1 of 4 Old 01-17-2014, 01:33 AM Thread Starter
Go4WD
Can anyone help document the different generations of 96-2006 clusters and pin/wire code for cross reference. That way we know which are interchangeable and what wires are needed if someone is swapping clusters. They look very similar from the front, but wiring plugs in the rear are very different. These clusters look very similar to Cherokee Clusters as well.
I have a collection of late model TJ & XJ Speedometer clusters and the mileage was not written down on them before they were pulled. If someone has the wiring schematics for these harness/plugs I will be able to log the mileage for each of them before listing them up for sale.
Hopefully this information will build a thread that can also help others in search of the right cluster for their replacement or swap.
Thanks in advance!
Picture 1 and 2 are from a 1996 TJ, Picture 3 and 4 are from a 2004 TJ
Go4WD is offline
post #2 of 4 Old 01-17-2014, 08:12 AM
angelo2975
I can email you the Jeep FSM
Try the link below
https://drive.google.com/folderview?...3M&usp=sharing
2002 FSM PDF version
angelo2975 is offline
post #3 of 4 Old 01-17-2014, 09:07 AM
JPGoody
JPGoody is offline
post #4 of 4 Old 01-17-2014, 09:12 AM
JPGoody
Also, I like your door black out section, looks like you did the pillars and rockers too, Nice!
When I 'monstaliner' my rock rails and rocker panels this spring I was thinking of doing the upper door part, looks good, think I will.
JPGoody is offline
cherokee , cluster , schematic , wiring , wrangler
