Designing a Rear Bumper/Carrier
I was in the market for a rear bumper/tire carrier when ColoradoSkier pointed me to A to Z Fabrication http://www.atozfabrication.com
I'm starting with:
Bumper--2"X5" rectangle tube with 3/16" thick wall, ends cut on angle and capped shut, 2" receiver in center. Tire carrier main tubes 1.75", with 1.5" supports, machined spindle with bronze bushings, T-handle screw-in latch to secure to bumper. Swing-away carrier with a hinge rated at 2000#. It is rattle free with the T-handle screw-in latching mechanism.
I have the option of making any modifications (or changes) I'd like so I'm planning to add mounts for a Hi-Lift to help balance the weight between the front & back once I purchase a winch.
Given the chance, how would you tailor this bumper to your needs? What would you change/add?
[SIZE=1][b]2000 Black TJ Sahara[/b] (manual) - R.E. 4.5 Super-Flex, 35" MT/R's, 15x8 AR767's, Ford 8.8, Dana 30, 4.88s, Eaton E-Locker, Lock Rite, Crane Covers, Nth Degree Shock Shifters, Bilstein 5150's, Atlas 4.3:1, Tom Woods shafts, Skid Row Engine/Oil Pan Plate, Kilby Tank Skid, AtoZ Fab 6-point Cage - Bumper/Tire Carrier - Stinger - Rockers, Line-X'd Interior, Flowmaster Fast Cat & a 40, Cobra 75WXST CB.[/SIZE]
