Dent in dana 44 diff cover - JeepForum.com
post #1 of 14 Old 12-09-2005, 09:52 AM Thread Starter
Buckeye Bill
Buckeye Bill's Avatar
My 2005 rubi unlimited was bought in Jan 2005. I recently noticed a dent on the front dana 44 diff cover. Dent is at the 6 o'clock on the cover and is about the size of a half dollar. It is about 3/16 inch deep. NO LEAKING! Don't recall hitting anything. Must have!
Any risk of gears rubbing on the pushed in portion of diff cover?
Any other concerns I should have?
Should I replace cover with OE and install skid or replace cover with stronger diff cover without skid?
Buckeye Bill is offline
post #2 of 14 Old 12-09-2005, 09:57 AM
jeeptj19992001
take off cover....hit it with a bfh...or rubber mallet...put it back on and then get a guard for it....or just get a rock crusher cover for it.
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #3 of 14 Old 12-09-2005, 01:16 PM
greggradwohl
Second that - rock crusher.
greggradwohl is offline
post #4 of 14 Old 12-09-2005, 01:20 PM
MuddyJeepZJ
MuddyJeepZJ's Avatar
BTF are good too!
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #5 of 14 Old 12-09-2005, 01:58 PM
The Mean Fish
The Mean Fish's Avatar
There are a ton of after market upgraded covers and skids that bolt over the stock cover (the skids are usually a bit cheaper and you don't have to replace the fluid to install most of them) but depending on the size and depth of the dent you may want to pull the cover just to make sure. On the stock covers you usually have a decent amount of space to play with, some of the aftermarket covers start to get tight to the gears because they're thicker and you have to worry about clearances with your steering and your gas take skid... I run Crane covers on mine and love them, they're a little pricey but I wanted the clearance they provide.
The Mean Fish is offline
post #6 of 14 Old 12-09-2005, 03:39 PM
JeepCreepn01
JeepCreepn01's Avatar
rock crushers, you aint going to dent them
JeepCreepn01 is offline
post #7 of 14 Old 12-09-2005, 03:49 PM
dirtgrip
dirtgrip's Avatar
Try these-1/4 in steel with 3/8 in ring. Dents-we don,t need no stinking dents. http://www.bluetorchfab.com/oscomm/c...c5e80f6343c6ee
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #8 of 14 Old 12-09-2005, 04:28 PM
rkik
I plan on replacing my covers front and rear with some CRANE covers soon. Everything I have researched on them is top notch and apparently recently they have made even more improvements. Plus no ribs like some of the other covers have to get hung up on. Rokmen ( www.rokmen.com ) has some good deals especially if you buy a set (front and rear).
www.highclearance.com/
rkik
rkik is offline
post #9 of 14 Old 12-09-2005, 04:57 PM
dirtgrip
dirtgrip's Avatar
rkik
No products until Aug 06!!!! http://highclearance.com/order/index.htm
dirtgrip is offline
post #10 of 14 Old 12-09-2005, 06:14 PM
UCTJ
UCTJ's Avatar
rkik
I am not worried about the ribs of a diff cover getting me hung up myself....I have a Crane front diff cover and you can get the new ones from www.raingler.com but after owning PSC rockrings, Crane diff covers, BTF, and now I am getting a Rockcrusher...I would go Rockcrusher b/c for not much more than the price of one Crane you can get 2 Rockcrushers from www.northridge4x4.com. They are all outstading diff covers IMO, but from a money stand point...the Crane diff covers are just overpriced!
UCTJ is offline
post #11 of 14 Old 12-10-2005, 07:49 AM Thread Starter
Buckeye Bill
Thanks for good information. That is why I keep coming back!!!
post #12 of 14 Old 12-10-2005, 09:38 AM
Dave@ROKMEN
Not true - Crane D44's are actually being machined now, and shipments are begining next week. With the D30's being cast now...
Crane is local to us, and we have a great relationship with them - so we usually have the good info...
(The August date on the website is old, and referred to Aug 2005 which has already passed)
Here are pics of the new covers:
Both RockCrusher and the Cranes are great covers - Different price points and different features differentiate them - both have a lifetime gaurentee.
-david(5+)
- Gear Up.... Rok On......
Dave@ROKMEN is offline
post #13 of 14 Old 12-10-2005, 03:20 PM
dirtgrip
dirtgrip's Avatar
Thanks for the info on Crane-must be time for them to update their site.AUG-Sep-Oct-Nov-Dec-5 months old.I agree they make 1st rate stuff!!
dirtgrip is offline
post #14 of 14 Old 12-10-2005, 07:43 PM
Scott_98TJ
I have hammered mine out about 6 times now, and that's even with using a Warn cover on my 44. It's protects the bottom portion, but I even manage to smash the top section of mine on the rocks.
Anyway, I'm not a fan of the Warns for that reason, and because they load up with mud (I can't avoid it around here...argh) and trap heat resulting in hard dried mud sandwiched in there all the time.
Love the Cranes, Rockcrushers and BTF's, wont have that problem with one of those.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
Is this a Dana 30 SOLID diff cover? TJamz TJ Wrangler Technical Forum 9 10-29-2009 09:26 AM
Clearance w/Dana 30 Diff. cover Cobra001 TJ Wrangler Technical Forum 4 05-01-2008 10:03 PM
Riddler Dana 30 Diff Cover Fit cajunjeep TJ Wrangler Technical Forum 8 08-07-2007 09:38 AM
Dana 35 diff cover removal ?? Allen52105 YJ Wrangler Technical Forum 6 07-23-2007 07:16 PM
Superlift dana 30 diff. cover? Tacoma750 TJ Wrangler Technical Forum 5 05-12-2006 07:42 AM
