DECEMBER TJ of THE MONTH CONTEST!! CVD IS THE WINNER!! - JeepForum.com
post #1 of 31 Old 12-14-2011, 09:13 PM Thread Starter
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Congrats
Username: CVD
Mods (optional):
Stretch:
- Frame stretched 7+”
- Pure Jeep tank, custom mounted for more stretch and ground clearance
- 102” wb
Suspension (all custom):
- 3 link front w track bar
- 4 link rear, triangulated
- 28” arms w JJ all around
- 12” Fox shocks, 4” Currie springs
- Currie anti-rock front & rear
Drive Train
- AW4 trans
- JK Rubicon D44’s front & rear, Superior shafts, Reid knuckles, front is sleeved, trussed, and gusseted. 5.38 gearing
- 37” MTR’s on 17” Racelines
Armor
- Custom flat aluminum engine, trans, & gas skids
- Savvy corner armor, cut for stretch.
- Metal Cloak fenders & flairs (modified for stretch)
Story (optional):
My TJ was very capable (33’s, locked front & rear) and I was satisfied with it until 3 things happened. 1) I rode with Robert Yates for an afternoon at JV and discovered how well a “Blaine Built” suspension can work, 2) I spent time in a friends LJ on steep waterfalls and liked the stability of the longer wb, 3) I spent an afternoon on Sun Bonnet with the Savvy gang (my lack of ground clearance caused me to need winching at least 12 – 14 times that day).
The rebuild (over the summer of 2011) had two primary objectives, 1) make it very drivable on the street for expedition type trips. I wanted to be comfortable driving 5 hrs on highway to one end of the Mojave Trail, then live out of it for 3 days on the trail. 2) be very capable on JV Hammers.
There were many key decisions as the build progressed, but the major decision was to build it for 35’s w my existing TJ D44 and an HP 30, or go to heavier axles and 37’s. When Blaine noticed a JK HP D44 in his driveway (belonged to Gerald), that started the ball rolling toward 37’s. From that point forward the entire build was designed to accommodate that tire size. Every steering link, control arm, spring perch, shock mount, bump stop, sway bar mount, etc. was built by Blaine for the 37’s – no more, no less.
Lastly, I wanted it to look somewhat as if it had come from the factory. Thus the aluminum fenders & corner guards were painted body color. The steel flairs and sliders were sprayed black.
Pictures:
Pic 1 explanation – rear stretch in-work:
1) cover plate over 7+” frame extension. Note the raised body mount, the 1” body lift puck is gone, more importantly the body mount is 1” further away from rocks.
2) frame arch pushed back, body wheel opening not yet cut
3) JK D44 positioned (control arm mounts, truss, out-boarded shock mounts, etc. not yet in place)
4) Stretch Tank mocked in place. Note the bottom of the tank is the bottom of the frame rail; this is several inches higher than the standard position for this tank. Later, the gas skid was fastened directly to the bottom of the frame
5) The frame rear was chopped off 7+”. My old rear bumper is now the rear cross member and it is raised 1” (body lift pucks removed in rear). Great departure angle.
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #2 of 31 Old 12-14-2011, 09:15 PM
Jason
Nicely done.
Jason is offline
post #3 of 31 Old 12-14-2011, 09:17 PM
StvDiego
Woohoo Cliff, congrats, I knew I shoulda stole those parts outta Blaine's driveway
StvDiego is offline
post #4 of 31 Old 12-14-2011, 11:39 PM
Sgt.Fuzz
Hard to argue against that rig. It'll be a serious contender for TJOTY, which should be any day now.
My build:
Sgt.Fuzz is offline
post #5 of 31 Old 12-14-2011, 11:46 PM
Necko2529
Well done. Congrats
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #6 of 31 Old 12-14-2011, 11:48 PM
Necko2529
It has started already, I think I've seen your tj in the bunch
post #7 of 31 Old 12-15-2011, 05:12 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
Very cool!
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists.” -- Don Colacho
grogie is offline
post #8 of 31 Old 12-15-2011, 07:50 AM
aw12345
Congrats Cliff
aw12345 is offline
post #9 of 31 Old 12-15-2011, 09:21 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Congrats!
Luck Favours The Prepared
Anticanman is offline
post #10 of 31 Old 12-15-2011, 01:22 PM
SummitSahara
Looks like fun waiting to happen!
SummitSahara is offline
post #11 of 31 Old 12-15-2011, 02:12 PM
RaggedOleMan
Cliff~
Congratulations, Cliff!
~jL
RaggedOleMan is offline
post #12 of 31 Old 12-15-2011, 03:20 PM
Brian86992
Sweet Jesus. I'm finding this build thread ASAP.
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #13 of 31 Old 12-16-2011, 07:38 AM
church
Rubi-Roo
church's Avatar
Nicely Done - Awesome Rig!
church is offline
post #14 of 31 Old 12-16-2011, 07:46 AM
MarkC73
Congrats!!
03 TJ Under Construction
Sienna Jeep Club: Member #70
MarkC73 is offline
post #15 of 31 Old 12-17-2011, 02:28 PM
JeepKat
Congratulations Cliff! Awesome Rig!
JeepKat is offline
OFFICIAL: DECEMBER TJ of THE MONTH CONTEST!!! VOTE NOW!! THE CONTEST HAS STARTED!! EugeneTheTJ TJ Wrangler Technical Forum 136 12-14-2010 07:57 AM
TJ of The Month Winner Announced!! RedLyner is the December WINNER!! spyder6 TJ Wrangler Technical Forum 36 01-12-2010 12:26 PM
TJ of The Month Contest winner announced!! FourbyCor is the October WINNER!!! spyder6 TJ Wrangler Technical Forum 28 11-30-2009 11:28 AM
TJ of The Month Contest Winner Announced!! GUNKEL IS THE SEPTEMBER WINNER!! spyder6 TJ Wrangler Technical Forum 40 10-26-2009 08:23 AM
TJ of The Month contest WINNER ANNOUNCED! -sean- IS THE AUGUST WINNER!! spyder6 TJ Wrangler Technical Forum 32 09-16-2009 07:28 PM
