death wobbles at 60+mph - JeepForum.com
post #1 of 6 Old 03-23-2008, 11:31 PM Thread Starter
dae03TJ
its a 03 tj 4" lift, adj. front track bar, pro comp steering stabilizer, balanced 32" tires... rides great up to 60mph, then goes out of control. any one else have a similar issue?
When in doubt, just gas it!!!
dae03TJ is offline
post #2 of 6 Old 03-24-2008, 05:56 AM
TheBoogieman
Disturbed Rubicon owner
TheBoogieman's Avatar
If alignment is good and tires are balanced perfect,search this forum.
TheBoogieman is offline
post #3 of 6 Old 03-24-2008, 07:47 AM
lj_wil
ekorb mi
lj_wil's Avatar
Sounds like it could be your pinion angle and your ujoints aren't happy, did you go ahead and get a SYE and CV driveshaft or did you drop the transfer case?
Here's some info on that:
http://www.4xshaft.com/driveline101.html
W6FU
lj_wil is offline
post #4 of 6 Old 03-24-2008, 07:51 AM Thread Starter
dae03TJ
jb supershort sye and tom woods cv driveshaft.
dae03TJ is offline
post #5 of 6 Old 03-24-2008, 08:01 AM
lj_wil
ekorb mi
lj_wil's Avatar
That definitely helps, how about your rear driveline angle?
W6FU
lj_wil is offline
post #6 of 6 Old 03-24-2008, 01:19 PM Thread Starter
dae03TJ
appreciate the help. i will check that when i get off work.
dae03TJ is offline
My Experience with the Death Wobbles haulincats TJ Wrangler Technical Forum 9 11-04-2009 01:53 PM
2006 wrangler death wobbles rake2011 TJ Wrangler Technical Forum 7 10-14-2009 11:46 AM
Need Help With Death Wobbles TrevorJordan TJ Wrangler Technical Forum 4 06-18-2009 05:30 PM
Death wobbles Chadillac1212 TJ Wrangler Technical Forum 7 01-27-2008 08:46 PM
Death Wobbles or something else? Coopa JK Wrangler Technical Forum 5 12-01-2007 10:36 PM
