I know there are a whole bunch of threads on this but i was curious if someone could just list off the possible problems that can cause it. Just the things that either need to fixed, tightened, or added. Thank you
Jack up the front end and place it on blocks, jiggle the tires up and down - and side to side to look for anything that might be loose. Look at your tie rods, track bar and all the connection for unusual movement.
There are times when you go out to the trails and bend a track bar or tie rod so look for that. If it looks all good then take it in to get a front end alignment (or do that yourself).
And remember that the bigger the tire the more prown to mis-alignment and death wobble.
The previous owner of my jeep had only put 2" springs on for the lift. The tires he had on it were somewhat chopped up and mis matched. They were all BFG AT's but some had a lot more tread than others, not to mention one of them was an old school tire that had a different side wall.
After putting on a new lift and relocating the trac bar, The death wobble was gone. All I noticed after that was some vibes in that speed area where the death wobble had occourred. Then I replaced the tires and had an alignment and the vibes seemed to disappear.
I originally replaced the stearing stablizer since the guys at the 4wheelparts store said the stock one was only good for about 15k miles. It helped some and made the wobble not quite as violent, but it was still there. I also lowered the pressure in my tires which helped with the death wobble, but isn't real good on your tires
I originally replaced the steering stabilizer since the guys at the 4wheelparts store said the stock one was only good for about 15k miles. It helped some and made the wobble not quite as violent, but it was still there. I also lowered the pressure in my tires which helped with the death wobble, but isn't real good on your tires
The most common causes are out of balance front tires or loose track bar.
You can easily diagnose a loose track bar by watching both of the mounting points while someone turns the wheel back and forth. You'll see the slop if there is any.
I dont have any steering dampner on mine and I have 9 inch springs and 35's and never get no death wobble. Make sure your alignments good. You want a good 7 degrees caster on you rig. Make sure everything is tight like its be mentioned. Upgraded track bars FTW
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
