Quantcast death wobble is scarry - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > death wobble is scarry
Old 03-23-2008, 12:01 AM   #1
Guitarhead09
today driving on the interstate , about 70 and then i was going gradually to the left hit a bump, then all hell broke loose. jeep started wobbling violently and my shifter moved so far it hit my leg, it was crazy, so i guess i need a new front alignment. i thought i was about to flip 8 times
Guitarhead09 is offline   Reply With Quote
Old 03-23-2008, 12:05 AM   #2
ribs
hahahahaha
ribs is offline   Reply With Quote
Old 03-23-2008, 12:35 AM   #3
_Yeti_
Yeah, tonight I experienced my worst death wobble. It bucked hard and I had to pull over to get it to stop. My friend next to me had a lot of questions that I could only explain with "its a jeep thing". I hate that saying, but find myself using it a lot.
www.DurtyRoK.com
Carolina Offroad
_Yeti_ is offline   Reply With Quote
Old 03-23-2008, 12:56 AM   #4
john NC
yeah, it's definitely not just a clever term
john NC is offline   Reply With Quote
Old 03-23-2008, 10:54 AM   #5
Snydermann
Junior Member
Snydermann's Avatar
Death wobble at 70 mph does not sound fun. I was experiencing it at 55 mph, and that was bad enough. I am not an expert, but you might have more than just an alignment problem. Worn or unbalanced tires, worn suspension parts, and other factors can cause the DW. In my case, new tires and a front end alignment cured the problem. Recently I discovered that I have been driving with a bent axle bracket that my lower control arm connects too. This has been causing odd vibrations at highway speeds. This too could have contributed to my DW.
I think there is a write up on the Death Wobble somewhere in this forum. Good luck to ya.
Snydermann is offline   Reply With Quote
Glock Forum
