Death Wobble is scarier with 37s... - JeepForum.com
post #1 of 6 Old 11-19-2012, 07:47 PM Thread Starter
TJe0454
So it all begun a couple months ago when i did many things i was told not to do. 1. military tires, 2. 16.5" wheels, 3. wheel adapters, 4. WJ knuckle swap.
Since i did all of that work, i have had some crazy death wobble that i could only get rid of by toeing it out a s**t ton. but it wore the inside (closest to jeep) of the tires down so that they look like drag slicks. only the inside half! i thought it was some play in my track bar/track bar mount, but now i have no idea!!
Possible causes (i believe)
1. wheel adapters
2. ball joints (gotta be uppers since i replaced the lowers with new WJ ones)
3. pinion angle.
4. idfk.
TJe0454 is offline
post #2 of 6 Old 11-19-2012, 08:05 PM
blubaru2002
Tires that are super out of balance can trigger DW.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #3 of 6 Old 11-19-2012, 08:10 PM Thread Starter
TJe0454
thats another thing... i tried balancing them when i worked at a tire center, but nobody will balance them...but they dw at low speeds too (sometimes 10mph), then the balancing would have little to no impact.
TJe0454 is offline
post #4 of 6 Old 11-19-2012, 08:38 PM
Holaday
no point in trying to balance them now that they are destroyed.
Holaday is offline
post #5 of 6 Old 11-19-2012, 09:30 PM
CrankyGypsy
there are lots of us with wheel spacers that don't get DW.
and when you say pinion, i assume you mean caster. you should be under 5 positive for 37s.
and everything connected to the front axle is suspect.
what are you running for steering?
2004 Rubicon
2005 Grand Cherokee Limited HEMI (fully optioned)
CrankyGypsy is offline
post #6 of 6 Old 11-19-2012, 10:18 PM
RaymoreRubicon
I was getting early signs of DW at about 10-15 mph on my 36". I took it in to have it balanced and 2 of my wheels were off by over 20 ounces! Needless to say... Balancing helps a lot.
RaymoreRubicon is offline
ball joints , death wobble , military jeep , track bar jeep
