#1 | |
Death wobble question
Hey everyone I no its been asked a thousand times over and over again, but I need some help on this one. Me and a Friend put on a full traction 3" lift today
and I cant get rid of the death wobble. The track bar is tight, everything is tight for that matter. i can drive it down the street and its fine, but as soon as i hit a little bump in the road the steering goes crazy, could this be the steering stabilizer? This is the same lift I put on my jeep, and I had no problems at all like this. So any ideas would be appreciated Thanks
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover |
#2 |
Have you done an alignment yet? New tires? Are they properly balanced?
2004 Silver TJ Sport 5 Speed Manual Dual Tops
3" BDS Lift 33x10.50 BFG M/T Warn Rocker Guards, Keystone Fab Rear Bumper & Tire Carrier w/ 48" Hi Lift Silverstar Headlights, Hella 500 Driving Lights |
#3 | ||
03' Sport, 4.0L, 3.73, 5 speed, D44/D30, 3 inch coil/shock lift, RE track bar, Tera disco's, 35x12.50's Dunlap Mud Rovers MT's, Spidertrax spacers, Viper 5000 alarm, Tuffy console, LOD extreme bumper/tire carrier and front bumper, A-Z rockers, AA SYE, Tom Woods DS, JKS Rear UCA's. Quote:
#4 |
no on the alignment and the balance, but it seems like this wobble is really bad
to the point where I cant even hold the steering wheel, and when i try to slow down it gets even worse for a few seconds, until i get below 35mph
#5 |
grab one of the front tires at the top, move it back and forth(push it in and out) and look under the car and you will be able to see what is loose
1998 Gun Metal Blue TJ LS1 powered TJ RIP- Brother rolled it. 2003 RCSB Silverado MP70 Turbo AKA Lightning killer http://www.jeepforum.com/forum/f7/my-v8-swap-blog-updates-365293/ |
#6 |
What the heck is "death wobble?"
#7 | |
#8 | |
Jeep
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#9 | |
Do it right or not at all
![]() Join Date: Jan 2003
First, as suggested above, get the tires PERFECTLY (!) balanced. Sometimes shops only get them "close enough" which isn't good enough. You say the trackbar is "tight", how do you know that? DId you tighten the bolts with a torque wrench? Grabbing the trackbar with your hands to test its tightness doesn't work as it can FEEL tight but it can still be loose enough to allow Death Wobble to develop. It's normally the lower mounting bolt that is loose, or its lower mounting hole is wallowed out. For 2003 and newer the lower trackbar mounting bolt must be tightened to 45 ft-lbs, 2002 and older 55 ft-lbs. If all that is ok, then sit down in front of your TJ while someone turns the steering wheel back and forth so you can look for something moving that shouldn't be moving. Especially look for movement at the trackbar's lower passenger-side mount. DW is commonly triggered by either a bump in the road or out of balance tires, but something else (trackbar, ball joints, bushings, etc.) must also be loose for the DW to actually fully develop.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#10 |
X2 Is is NOT the steering shock. Can't add more than guru Jerry mentioned.
#11 |
I had the same problem when I lifted mine.
The new track bar had a hole sized for a 5/8" bolt and the OE track bar had a 1/2" bolt. Somebody left that out of the instructions. Even tightened, it shook like an earthquake. When you are parked with the motor running can you turn the steering wheel and see any movement up front? That would be the second place I would look. The first has already been mentioned (tire balance and alignment). |
#12 |
Italian Wheeler in Mexico
to check the track bar ( i had a problem with it, that's why i'm telling you to do so) have a friend moving the steering wheel while you check it out. If you notice a side to side movement on the lower trackbar mounting location (on your axle) than that's is the culprit
#13 | |
#14 | |
#15 |
If it is on the 2000 Sahara, you might also, start checking suspension parts, as in ball joints, and wheel bearings, tie rod ends etc............. as you should have enough miles, they could be worn..............
Pick |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
