Death Wobble Poll: CA Bushings - Page 2 - JeepForum.com
View Poll Results: When you experienced DW, what kind of front CA bushings were you running?
Stock OE Clevite (rubber) 128 73.56%
Poly 9 5.17%
Mix of Rubber and Poly 7 4.02%
Johnny Joints 8 4.60%
Mix of Johnny Joints and Rubber 11 6.32%
Heim Joints or other-brand articulating joint (RC, RE, etc.) 3 1.72%
Mix of Heim/other joints and Rubber 8 4.60%
Voters: 174. You may not vote on this poll
post #16 of 31 Old 09-01-2010, 09:27 AM Thread Starter
-dirt-
Originally Posted by conrasm View Post
I had DW due to wallowed out track bar hole on axle and poorly balanced swampers.
Originally Posted by -dirt- View Post
Ok! But would you still mind contributing to the poll with the information regarding your CA bushings?
-dirt- is offline
post #17 of 31 Old 12-26-2011, 09:24 PM
RaggedOleMan
I fought with DW for quite some time. In the spirit of the OP's intentions for this thread, and with regards to bushing's, the upper bushings on the axle end were, in my estimate, the major contributor in my case. I ended up swapped them out in favor of the Currie/Johnny Joint style. This resulted in the single biggest improvement to my DW at the time, though it wasn't completely gone. Soon after that, when the budget allowed, I swapped out all 4 of the front control arms to Currie with Johnny Joints.
I need to add though, that my steering linkage was complicit, too, and I changed it out to Currie. The front factory track bar was also complicit so I swapped it out in favor of a JKS...and, before I finally got the DW resolved, I'd completely worn out the ends of the new Currie drag link... One end was due to my "over greasing it", the other was a victim of the DW...
DW was in my case, vicious. To minimize further damage to my front end, each time I repaired/replaced something, I'd go for a test drive only to discover the DW was still there. So, I would set the toe "out" 1-1/4". I was taught that by doing this, the DW symptoms will disappear, and they did. The down side is whatever caused the DW was still there, and driving with the toe out that far made driving a white knuckle affair. However it would buy me time for my repair budget to get beefed up again, without continuing to wear out my front end components faster than I could replace them...
RaggedOleMan is offline
post #18 of 31 Old 12-26-2011, 09:29 PM
J03_TJ
X2 on the wallowed out hole and me it was a set of 33x10.50 tires that I think were never balanced right. Made me think tall skinny squishy tires had something to do with it also.
J03_TJ is offline
post #19 of 31 Old 12-26-2011, 09:34 PM
RaggedOleMan
As I went through the DW, I never balanced my tires. Only AFTER the DW was completely gone did I have them balanced. And I keep them balanced...it's been said before, but perhaps it needs repeating that out of balance tires don't cause DW. Out of balance tires wear out the front end components, that causes DW. So yes, I agree that tires have a part in the movie...
post #20 of 31 Old 12-26-2011, 11:17 PM
jbjeepfever
So if the DW had nothing to do with CA bushings and still want a persons poll, then exactly what facts are you on the hunt for about DW and CA bushings? Would seem your findings would be a little skewed
jbjeepfever is offline
post #21 of 31 Old 12-27-2011, 12:01 AM
Sgt.Fuzz
Out of round tires do.
My build:
Sgt.Fuzz is offline
post #22 of 31 Old 05-26-2012, 05:41 AM
speeduck
New jeep, 26 thousand mules, budget boost puck lift, never intend to wheel this jeep, (to satisfy the wife) its her driver.... Now its her slow driver, any bumps at 50, and DW ..... Ughh. budget boost coming out and going to do a chaep body lift... Gross.
speeduck is offline
post #23 of 31 Old 05-26-2012, 07:22 AM
flying_bosun
Do you have it in your mind that removing the budget boost for a body lift is going to cure DW? If so, you might want to read up some more....
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #24 of 31 Old 05-26-2012, 11:37 AM
JEK3
JEK3's Avatar
Swapping in poly bushings reduced my DW to an occasional shimmy.
JEK3 is offline
post #25 of 31 Old 05-26-2012, 11:46 AM
stwilson74
stwilson74's Avatar
Unless your talking about a JK in the TJ section thats not a new Jeep... time affects rubber and any TJ/LJ is at least six years old. I doubt the BB is the real root issue, you might want to take a closer look.
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
Originally Posted by Necromancer_tat View Post
I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:
stwilson74 is offline
post #26 of 31 Old 05-26-2012, 12:00 PM
gatesjeff33
When I got new tires, it was 90% gone, When I got new ball joint, TRE, outer TR, and draglink from MOOG it was 100% gone. I do run a dual steering stabilizer on 31 in tires though....
gatesjeff33 is offline
post #27 of 31 Old 05-27-2012, 02:48 PM
Pillswoj
My last case of DW was worn bushings on my front lower Rock Krawler Control arms. I replaced the bushings with Johnny Joints.
Friends don't let Friends run Bosch
Pillswoj is offline
post #28 of 31 Old 05-27-2012, 03:32 PM
BamaJeepman21
Senőr I would very much love to have your 26,000 mules.
-Jack
BamaJeepman21 is offline
post #29 of 31 Old 05-27-2012, 10:19 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
LMAO!
Necromancer_tat is offline
post #30 of 31 Old 05-27-2012, 11:28 PM
alex211
1995 XJ Cherokee
I never got DW with all stock front suspension components running 33s with 150k on them. It did have a nasty shimmy at about 45 though.
With currie arms, currie trackbar, and ZJ tie rod the shimmy is almost completely gone. I'm thinking a johnny joint housing kit to get rid of the last of the rubber bushings will really tighten up the front end, new ball joints will probably help too. I did notice a big change in just changing the control arms to curries though, rubber bushings have no place in the jeep that actually gets wheeled. IMO
95 xj bone stock for now
alex211 is offline
dw , death wobble , control arm , bushings , tj , wrangler
Front End Wobble at 55-65 -- But no death wobble pfifer TJ Wrangler Technical Forum 17 04-02-2013 01:16 PM
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
DEATH to the death wobble....wooohooo jeeperscreep04 TJ Wrangler Technical Forum 6 09-19-2009 01:31 PM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
is it death wobble or death steer frank_frank139 TJ Wrangler Technical Forum 4 03-06-2007 11:56 AM
