**Death Wobble=loose steering box?** - Page 2 - JeepForum.com
post #16 of 31 Old 01-05-2013, 09:37 AM
biffgnar
biffgnar's Avatar
While I agree that he should have an SYE and double cardan driveshaft for the lift he has, I've got to say that I don't think the pinion setting is necessarily wrong as is. You guys are focusing on the fact that the pinion and driveshaft are inline, but take a look at the relationship between the pinion and the TC output. They look pretty parallel to me which is the correct setting. It just so happens that with his TC drop in place that puts the driveshaft inline also. Yes, the TW diagram has both outputs horizontal, but thats not the point. The point is they should parallel whatever that is so the ujoints are splitting the angles equally.
Romney in 2020!
biffgnar is offline
post #17 of 31 Old 01-05-2013, 09:45 AM
TroubleNEO
I agree with you on them being parallel, but after running angles just like that on my rear I was blowing through ujoints fairly quickly. After getting ready to replace them a third time between Nov-Jul I said screw it and went with the CV shaft and changed everything around to be correct.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #18 of 31 Old 01-05-2013, 09:49 AM
Imped
Imped's Avatar
One thing is for sure. The PO of that Jeep had no clue what they were doing.
OlllllllO
IndyORV
Imped is online now
post #19 of 31 Old 01-05-2013, 09:55 AM
biffgnar
biffgnar's Avatar
Yes, but that is the point of needing the CV shaft which I acknowledged. But you told him the geometry of his current shaft was wrong, which is bad advice. The geometry is correct for the shaft he has. Or put another way, with the shaft he has how would you change the pinion orientation?
Romney in 2020!
biffgnar is offline
post #20 of 31 Old 01-05-2013, 10:00 AM
TroubleNEO
I think we can all agree on that.
You are right, his geometry is not technically "wrong" if we're going by the book. I was saying it was wrong from a personal experience standpoint where I ran like that and had issues. I will admit there is nothing he can currently change or adjust to make the angles "right" and it was incorrect to say that his current geometry is "wrong" going by the book.
post #21 of 31 Old 01-05-2013, 10:24 AM Thread Starter
skizman
Allright. Now you guys got me in a tailspin. Thankyou for the bad news...I mean it....thankyou! I'm picking up a new track bar today, so I'll start with that. I've got my homework
now. I really appreciate you guys to take the time to help me out. Hopefully in the next week I can make it all happen.
skizman is offline
post #22 of 31 Old 01-05-2013, 10:30 AM
TroubleNEO
What kind/brand of new track bar? Don't go buying more garbage and exacerbate your issues.
post #23 of 31 Old 01-05-2013, 06:18 PM
tjsean0308
A four inch lift really should have an adjustable trac bar. The stock one will have to use the new hole and that is not ideal. Also for the dry steering test leave the jeep on the ground. The weight of the vehicle on the tires will help expose any movement by creating more force on the trac bar and steering components.
tjsean0308 is offline
post #24 of 31 Old 01-06-2013, 03:51 PM Thread Starter
skizman
My happy news! I installed a new track bar in the front and bolted it to the original hole on axle side and......95% of the steering wheel shaking is gone! What a relief! You guys made alot of comments about checking the track bar. I thought about just buying the bushing and tie rod end, but considered the major hassle of trying to press the old out and new in and I didn't need to go through all that grief, so I just bought the new track bar...ready to go.
Thankyou for you help!!! Now I need to smoke my brain about the rear drive shaft.
skizman is offline
post #25 of 31 Old 01-06-2013, 04:22 PM
The_Dealer
2003 KJ Liberty
Seeing the diagrams it looks backwards. I thought cv shafts/sye needed the pinion lower then being paralell? Or am I confused? In my yj with sye I had to remvoe the pinion shims that came on my loft springs.
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #26 of 31 Old 01-06-2013, 04:26 PM
rchase559
Your YJ had axle wrap because of the leaf springs. Under load, the axle housing rotates causing the pinion to point slightly upwards.
This is not the case with the link suspension on the TJ
rchase559 is offline
post #27 of 31 Old 01-07-2013, 06:40 PM
The_Dealer
2003 KJ Liberty
ah ok, I thought maybe it was just a leaf thing. Now I.learned something new
My build
post #28 of 31 Old 01-07-2013, 07:17 PM
jeeptjrn
If nothing else I would consider adjustable trac bar. The angles on your pitman arm seem sharp but may just be the picture.
jeeptjrn is offline
post #29 of 31 Old 01-08-2013, 02:25 PM Thread Starter
skizman
I just installed a new stock trac bar and I'm glad I did.
Thanks.
skizman is offline
post #30 of 31 Old 01-08-2013, 06:08 PM
tjsean0308
How far off center is your front axle? I would think about re-enforcing that axle bracket they tend to crack with that extra hole.
death wobble , steering box
