Quantcast Death Wobble From Hell!!! Help. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Death Wobble From Hell!!! Help.
Old 01-17-2010, 10:17 PM   #1
WKENDWARIOR69
Hey guys, I have been working on this problem for awhile. I can't seem to find out what causes it. I have changed the steering stabilizer, replaced the whole steering linkage with a Currie HD system (had too, old one bent). Replaced track bar mount to the Nth degree system in turn forcing me to change out the drop pitman arm. Adjusted toe-in in by up to 1/4" and out by 1/4", had the tires rotated and balanced. Adjusted caster from pos 5degs to pos 12degs. checked all bolts and rubber bushings on my JKS lower control arms, and stock upper control arms. Change the brakes, checked bearings, and spindle ball joints. Everything looks to be right, and as far as i know there is nothing else to check.
Any help would be great, thanks guys.
l _____
/l ,[____],
l---L –()lllllll()-
()_)-()_)--o-)_)
TWS Designs
WKENDWARIOR69 is offline   Reply With Quote
Old 01-17-2010, 11:20 PM   #2
MisfitSeven
MAIL Crawler.
MisfitSeven's Avatar
my buddy had a simple fix you might want to check. he had his rotors turned and that fixed his DW after lifting his TJ.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
Originally Posted by Patton View Post
You won the nicest mail jeep award.
I'm typing this real slow to try and help you.
NEW and USED parts for sale. PM me.
MisfitSeven is offline   Reply With Quote
Old 01-17-2010, 11:27 PM   #3
02tjsport
Check the trackbar bolt on the axle side. That hole wallows out and causes DW. Take the trackbar off, push the bolt in the hole by itself and see if it is wallowed out. It should fit flush in the hole.
Mine did the same thing, my DW was so bad it sheared the frame side trackbar bolt while it was wobbling.
Upgrade to a bigger size bushing (I went with a 1/2" bolt) they are cheap from mcmaster.com.
Or, you can weld a 1/4" thick plate of steel the front side of the mount and drill it for the stock bolt size.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 01-17-2010, 11:36 PM   #4
97tjfinatic
check your u joint on everything sounds stupid but if your u-joint is goin bad it could cause a pretty bad vibration or wobble. Then your driveshaft falls to the street trust me happened three days ago
I LIVE, I RIDE, I AM.....JEEP
97tjfinatic is offline   Reply With Quote
Old 01-18-2010, 08:02 AM   #5
WKENDWARIOR69
I will check my track bar connection at the axle tonight. When I have someone steer the wheel back and forth I cannot see any movement at that joint, but will still check.
It cant be the brakes cause I just changed them to see if that effected the wobble.
This is no wobble from a bad u-joint, I have pulled my drive shaft and checked all. Also note that this is not a problem that only shows up at 45+ mph. I can hardly get out of 2nd gear or 1st sometimes before the shaking starts so bad that I am smoking the tires from the side to side motion.
Anyway keep the ideas coming and I will check what ever you guys think of.
Thanks.
l _____
/l ,[____],
l---L –()lllllll()-
()_)-()_)--o-)_)
TWS Designs
Old 01-18-2010, 08:24 AM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
How did you check the ball joints and bearings?
Have you tried pushing on top of the front tires while the Jeep is sitting on the ground? This is another good way to find something that is loose.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 01-18-2010, 08:30 AM   #7
tlendt
If nothing else works you might get your tires "road force" balanced. Many of your bigger tire stores have these machines. Cost me $20/tire but it worked.
tlendt is offline   Reply With Quote
Old 01-18-2010, 08:56 AM   #8
Niceface
This happened to me several weeks ago. Tightened up the bolt, torque'd it down, and all the play/wobble went away....for now. I'm sure it's lurking somewhere, just waiting to cause havok again! Curse you DW!
JGM Enterprises- Click It!
Niceface is offline   Reply With Quote
Old 01-18-2010, 09:53 AM   #9
robncar
If you have aftermarket wheels, make sure the star washers are not on the wheel studs to retain the rotor hats. Factory wheels will clear, aftermarket may not. The washers will not allow the wheel to sit flush on the hub.
DON'T FEAR THE RE-GEAR!!!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Old 01-18-2010, 10:00 AM   #10
AngusTJ
I hate DW!!
"Run what ya brung and hope ya done brung enough"
Originally Posted by pjleslie03 View Post
I know how bad the D35 is in the rear, but would it be bad to have one in the front?
Originally Posted by Lostj View Post
yes, you wouldn't be able to steer
98' TJ, 4" Superlift, JKS 1.25" BL/ 1" MML, 8k Gorilla winch, Cowl intake, D30 Aussie, shafts/D44 Powertraxx, shafts (4.56's), Rusty's Adj CA's front/ RE Adj CA's rear, Recessed tails, sway discnct'd, 152 db train horns, 34x10.5 LTB's Amer Rac/36x13.5 Irok's Streetlocks, Grenade shifter, Pioneer deck/speakers, Warn bumpers, KC upper lite mts/Slim lites, EBC yellows, 40 series Flowmaster, couple tasteful more ...
AngusTJ is offline   Reply With Quote
Old 01-18-2010, 10:12 AM   #11
WKENDWARIOR69
what is this? how do i know they are doing it and not just the normal balancing act.
l _____
/l ,[____],
l---L –()lllllll()-
()_)-()_)--o-)_)
TWS Designs
Old 01-18-2010, 10:13 AM   #12
WKENDWARIOR69
I have removed the stars awhile ago. good thoughts.
l _____
/l ,[____],
l---L –()lllllll()-
()_)-()_)--o-)_)
TWS Designs
Old 01-18-2010, 10:16 AM   #13
jjenkins11
i tried/replaced a few things on my 'stock' jeep...and what finally fixed it was new tires...
"you don't drive a jeep.......you ride one"
http://www.frozentimephotography.net
jjenkins11 is offline   Reply With Quote
Old 01-18-2010, 10:18 AM   #14
tlendt
Call and ask if they have the machine. I watched them do mine through the window in the waiting area. I have regular access to a good Coats spin balancer and it just couldn't get it. The road force balancing was like magic; it exceeded my expectations. And cured my death wobble.
Old 01-18-2010, 10:21 AM   #15
Wheelin98TJ
JEEP FREAK
Here is a locator for shops with a road force balance machine:
Locate a Hunter GSP9700 Wheel Vibration Control System
98 TJ
Glock Forum
