Death Wobble fix the easy way check it out. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Death Wobble fix the easy way check it out.
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 06-17-2010, 07:03 PM   #1
sburton1
Ok so I recently purchased a currie HD track bar set it up and still had DW. I read about drilling out the lower mount and installing a larger bolt.....Have yoiu every tryied to drill that thing hard no thanks. so I removed the lower part of the link and looked at it.hmmmmmm I noticed that it was a rolled bushing, si I hit it with a large punch a few times untill the new 7/16 bolt would fit snug then drilled the lower frame with a 7/16 bolt. Presto DW fixed, so If you have DW and a jks or currie track bar this might work for you! sorry no pics kinda forgot...
sburton1 is offline   Reply With Quote
Unread 06-17-2010, 07:55 PM   #2
RockMonster
Awesome. Just waiting for mine to come back. When it dose ill give this a try!
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++++++
RockMonster is offline   Reply With Quote
Unread 06-18-2010, 07:48 PM   #3
sburton1
ya it was so easy and one of those light bulb moments. the 10mm bolt is kinda small in the lower track bar mount 7/16 is perfect.
Unread 06-18-2010, 07:55 PM   #4
mrblaine
mrblaine's Avatar
Just for the sake of curiosity, why it is that I have 4 TJ's in my driveway that use a 10mm bolt on the front trackbar and none of them have DW?
One of them is even running new Kevlar MT/R's on beadlocks that are unbalanced?
I am Savvy
blackmagicbrakes.com
mrblaine is online now   Reply With Quote
Unread 06-18-2010, 07:59 PM   #5
fire239
I would think it would be undersized only if the hole for the bolt was ob longed. Maybe Jeep ran out of 7/16 the day they built yours and just threw in a 10mm?
fire239 is offline   Reply With Quote
Unread 06-20-2010, 12:47 PM   #6
sburton1
ya my hole was oval real bad so for me it made a diff.
Unread 06-20-2010, 01:03 PM   #7
dualtjs
2011 JK Wrangler
Sounds like the bolt was loose at some point in time and wallowed out the hole.
dualtjs is offline   Reply With Quote
Unread 06-20-2010, 02:10 PM   #8
cheapjeep06
I had a similar problem at one time. Stock bolt was loose in steel sleeve in tb bushing, and really loose in the axle mount holes. But hole was not oblong or oval. 7/16" bolt fit snug in the hole, so I drilled out the steel sleeve and installed the larger bolt, tapping it in with a hammer. Tightened it up and all was well.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline   Reply With Quote
death , wobble
