Death wobble fix? - JeepForum.com
post #1 of 26 Old 10-27-2012, 10:06 AM Thread Starter
Woodcock1187
Death wobble fix?
hey everyone i have a 05 tj with a RC 3.25 lift had the lift on for 5 month and this started today after i replaced my steering dampener. Any ideas on how to fix this??
Woodcock1187 is offline
post #2 of 26 Old 10-27-2012, 11:56 AM
MVintherTJ
Do a dry steer test. Check your trackbar at both ends and your tie rod ends as well.
MVintherTJ is offline
post #3 of 26 Old 10-27-2012, 01:13 PM
JEK3
JEK3's Avatar
Replacing the steering dampener usually makes DW go away (well, at least hides it for a while). What did you have on there before, and what did you replace it with? Did you change anything else in the process?
JEK3 is offline
post #4 of 26 Old 10-27-2012, 02:24 PM
MVintherTJ
No. It only masks the problem. A steering stabilizer is never the correct solution to death wobble.
post #5 of 26 Old 10-27-2012, 03:35 PM
mldlegend
New steering stabilizer did not fix problem. BFG AT 30000 miles out of balance . Bounced like a basketball than DW. Two tire dealerships could not figure out the problem.The local Jeep dealership balanced the tires and drives great up to seventy five. 05 tj 4 inch lift 35 12.50 15 at 60 dollars is what it cost.
mldlegend is offline
post #6 of 26 Old 10-28-2012, 09:08 AM
JEK3
JEK3's Avatar
That's why I said "(well, at least hides it for a while)" - meaning your DW stops happening, but will probably come back with a vengeance.
JEK3 is offline
post #7 of 26 Old 10-28-2012, 09:47 AM
Moezer
2015 JK Wrangler
When you did our lift did u relocate or track bar? Or or tc drop? When I did mine I hav e to move the track bar to align the axle also when I put in the etc drop I had major DW felt like the jeep was hopping off the ground.
If u have your tc drop remove it and see what happens
Moezer is offline
post #8 of 26 Old 10-29-2012, 06:15 AM
gecsr1
What is a " TC "
gecsr1 is offline
post #9 of 26 Old 10-29-2012, 06:27 AM
1shotwonder
Transfer case... Aka 4 wheel - 2 wheel drive case
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #10 of 26 Old 10-29-2012, 06:29 AM
Dean7276
Originally Posted by gecsr1
What is a " TC "
Transfer case
Dean7276 is offline
post #11 of 26 Old 10-29-2012, 03:29 PM
Moezer
2015 JK Wrangler
The transfer case drop by that its a drop for the bottom skid plate so our trans along with our TC are lowered to a company the lifted angle of the derive shaft u can also lift up our engine instead and u won't have much of an angel on the front drive shaft but like I said I had it on mine and it scared the crap out of me so I took the spacers out
Moezer is offline
post #12 of 26 Old 10-29-2012, 05:07 PM Thread Starter
Woodcock1187
well i fixed it. the new one i put on was a monroe from oreillys but i took that off and put the old one back on and notice that the track bar was a little loose at the axle so i tightend that up and the problem went away. i will throw the new one back one when i get time and see if that was the problem or if it was the loose track bar. Thanks for the advise everyone
post #13 of 26 Old 10-30-2012, 07:06 AM
gecsr1
I just started getting the wobble too on my TJ.......I have 35's, 4" lift with front spring spacers 2". Short Arm kit. The tires balanced out well, and the front end is aligned and tight. But my steering stabilizer was old...also have Currie tie rod and stabilizer bar, Steer Box Drop Arm.
But my problem was the steering stabilizer... bought one on line from Rough Country and my problem went away........
There's lots of crap that can contribute the the "Death Wobble"
gecsr1 is offline
post #14 of 26 Old 10-30-2012, 07:49 AM
rchase559
And a steering stabilizer is not one of them.
rchase559 is offline
post #15 of 26 Old 10-30-2012, 10:00 AM
gecsr1
I beg to differ.... If I hint a bump or small pot hole my jeep would go into wobble.... the only thing I changed was the STEERING STABILIZER.....
(the old one was Rancho and it was 9 years old)
as far as I'm concerned... it plays a part in the WHOLE PICTURE.....
Have a Good Day.....
gecsr1 is offline
death wobble
