Death Wobble during braking? - JeepForum.com
post #1 of 20 Old 08-07-2007, 07:46 PM Thread Starter
chaz7979
I have an 03 X that runs smooth as hell and has for 4 years until now. If I am doing over 50 MPH and hit the brakes the front right tire (only the front right) goes into a death wobble until I come off the brake. Is this just an issue with my brakes or could it be something else? Everything else feels tight down there.
chaz7979 is offline
post #2 of 20 Old 08-07-2007, 07:49 PM
jeepnmike
jeepnmike's Avatar
I'm no brake expert, but I'm gonna say its a warped/bent rotor. You checked the lugs right?
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #3 of 20 Old 08-07-2007, 08:01 PM
JeepRide
JeepRide's Avatar
x2 sounds like warped rotors
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #4 of 20 Old 08-07-2007, 08:27 PM Thread Starter
chaz7979
I will go check the lugs right now. Thanks guys.
How do rotors get warped?
chaz7979 is offline
post #5 of 20 Old 08-07-2007, 08:38 PM
Sweeney
They can warp from excessive heat or (not really warping) the non uniform buildup of pad material on the rotor surface. Check your bearings while you're at it.
Sweeney is offline
post #6 of 20 Old 08-07-2007, 09:49 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Why do you think it's only the right front?
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #7 of 20 Old 08-07-2007, 10:16 PM Thread Starter
chaz7979
I can tell that it is only the right front because the shaking is so violent it is clear where it is coming from.
How exactly do I check my bearings? I do know a bit about cars and I am pretty handy, even though I don't know a lot of the little things (ie bearings)
chaz7979 is offline
post #8 of 20 Old 08-07-2007, 10:30 PM
am3rican
definitely sounds like your rotors are warped and need to be shaved down.
am3rican is offline
post #9 of 20 Old 08-07-2007, 11:14 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not really. If it's only the right front, that rules out several things and brings a few more up front and center. Bad rotors will show up in the steering wheel and shake it pretty good.
It could be the TRE at the knuckle because if it's only the RF that's wobbling, then the connection to the other side has to be broken which narrows it down to that TRE. If it was the ones in the tie rod, then he would feel it in the steering wheel through the draglink.
Also, it's very rare for only one rotor to go bad, not impossible, just rare. It could be a combination of a bad rotor though, and a bad wheel bearing.
I am Savvy
post #10 of 20 Old 08-08-2007, 05:04 PM Thread Starter
chaz7979
I do feel it in the steering wheel pretty good and now that I think about it, I went off the road over the winter and that right front hit a snow mound. Dont blow this out of proportion...I was doing about 3 mph and sliding sideways, the road was frozen and I was trying to stop in the middle of the road and when I came to a stop the jeep slid to the right just from the natural run off shape of the road. It was enough to crack my fender flare but it was so soft and slow I doubt it broke anything mechanical.
My real issue here is that I dont know any good shops in my area and I dont want to get raped if I drop my car off to get fixed. So I am looking for the most obvious issues and what they might cost to fix.
chaz7979 is offline
post #11 of 20 Old 08-08-2007, 05:54 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm not sure why you want to try and get help and then leave out key bits of info.
Unless the ends are bad in your tie rod, then the left side is shaking as well.
Why don't you have someone ride with you that can watch the tires while you drive with some safety glasses on and see if they can get some more info to help with the diagnosis.
It also might help to know what area you are in.
I am Savvy
post #12 of 20 Old 08-08-2007, 07:22 PM Thread Starter
chaz7979
I guess its because its hard to explain. Its not like the steering wheel shakes all over the place, its more like when it is shaking during breaking and I try and turn I really feel it.
If that is the case the left side is shaking about 1/10 of what the right side is doing.
Boston MA
chaz7979 is offline
post #13 of 20 Old 08-08-2007, 07:37 PM
jcm11881
Death wobble seems to be the most over-used term on this forum. Somebody correct me if I am wrong, but I believe DW is caused by a loose trackbar and it is so violent that it only stops when you stop the jeep.
jcm11881 is offline
post #14 of 20 Old 08-09-2007, 11:53 AM Thread Starter
chaz7979
It can also be caused by improperly balanced tires and in my situation the wobble is that bad. Its so shaky its scary, and I'm not exactly easily scared.
chaz7979 is offline
post #15 of 20 Old 08-09-2007, 12:06 PM
Dragon158
Recently got a wobble after doing a 2" BB. I had a brake pulsation and it intensified it after doing the lift. Same thing you describe, @ 50 or so mph and braking. I was under the impression that the stock rotors are composite. I've had issues with Grand Cherokee composite rotors for a few years, I just figured the Wrangler were similar composites. You can also get a warped rotor from going hot to cold. It happened to me, I hit a puddle that caught me by surprise after a few hours of driveing up and down mountains in WV. I had a pulsation all the way home after that... until I swapped rotors.
Dragon158 is offline
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 08:25 AM
Death Wobble, When Braking at Speeds over 50MPH tdog522 TJ Wrangler Technical Forum 2 03-25-2008 05:13 PM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 01:29 PM
crazy (death?) wobble while braking badoosh27 TJ Wrangler Technical Forum 7 04-19-2007 04:00 PM
Wobble while braking JonRobert TJ Wrangler Technical Forum 8 06-23-2006 10:16 AM
