Death Wobble Cause? - Page 2 - JeepForum.com
post #16 of 26 Old 01-11-2014, 07:05 PM
JBTJ
Originally Posted by MzCoop View Post
Yep. I've got tools, I'm just still learning my Jeep...
Find the right size socket to fit the bolt on the TB axle side and see if it's loose.
JBTJ is offline
post #17 of 26 Old 01-11-2014, 07:06 PM
TJSIDNEY
Sorry I gave so much randomness.. He said he wanted info before he went to the Mechanic.. I was just throwing it out there. IMO I would look at the joint from the Drag to the Pitman as well..... especially if the Tracbar was totally broken .. I was kinda being random for information sake. I will shut up now. I like the advice of getting tools and taking it on yourself. I made the mistake of trusting a mechanic more than once.
Have you ever had someone say “I read online that….” Really? You read it online so that makes it true? Sometimes yes, but where did you get your information?
TJSIDNEY is offline
post #18 of 26 Old 01-11-2014, 07:07 PM Thread Starter
MzCoop
I'll try that.
MzCoop is offline
post #19 of 26 Old 01-11-2014, 07:09 PM Thread Starter
MzCoop
I wanted as much info as possible I appreciate it!
I can't get under it right this minute. I will def do that asap and get back to y'all tho.
MzCoop is offline
post #20 of 26 Old 03-11-2014, 04:49 PM
mgclark6
OP, did you find/fix the problem? Im starting my search for the cause of my Death Wobble after i installed my 2.5" OME lift of my '05 LJ. Gonna start with track bar and some other info these fine people suggested.
mgclark6 is offline
post #21 of 26 Old 03-11-2014, 05:07 PM
afusco1222
Did you loosen your control arms before putting the lift on? Do you have aftermarket control arms or stock? Have you checked the trackbar bushing? Have you looked at the ball joints, TREs, upper control arm axle bushings? Have you done a dry steering test? If you check all of these parts and do the dry steering test, that should reveal what is loose.
afusco1222 is offline
post #22 of 26 Old 03-11-2014, 05:21 PM
mgclark6
Wow, that was quick! No on loosen control arms, they are stock, new JKS trackbars with new bushings, checked torque-OK, just did dry steer and all looks fine, need to check ball joints, all control arm bushings feel tight (will look into further) what is TRE?
I DID FIND.....right front axel U-joint is bad. Will replace tomorrow.....could this cause wobble?
mgclark6 is offline
post #23 of 26 Old 03-11-2014, 05:42 PM
afusco1222
It would cause a shimmy but not death wobble. You need to loosen all of your control arm bolts to relieve the bushing of bind. That will help some if your bushings aren't shot. You don't have to take the bolts all the way out, you just need to loosen them enough to relieve the joint.
post #24 of 26 Old 03-11-2014, 05:49 PM
mgclark6
Sounds good, I'll try that in the morning and report back. Also gonna replace that axel U-joint and put a new steering stabilizer on (its still stock stabilizer)
Thanks a bunch!
mgclark6 is offline
post #25 of 26 Old 03-11-2014, 09:30 PM
carnuck
1984 J-Series Truck
Alignment usually makes it go away. Was the original tracbar for a lifted front end? If so, I see where the problem came from.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #26 of 26 Old 03-22-2014, 07:57 PM
mgclark6
Found this awesome link, had to share.
http://www.wranglerforum.com/f210/di...ion-78090.html
mgclark6 is offline
death wobble , track bar
